Mahle s2k pistons
Originally Posted by B5254T4' timestamp='1373051530' post='22649187
The good old o-rings but used copper instead of steel wire this time because of the MLS gasket and steel cylinders. Just to add some extra pressure.
Darton do this on the 50psi+ engines, maybe overkill for me but easy to do when the engine is stripped.
Originally Posted by wadzii' timestamp='1373066202' post='22649522
The NA pistons are 4032 alloy, they are not suited to boost, they also come with tapered pins, which arent strong enough for boost.
With an ap1 crank +6cc will get you 11.5:1, with ap2 crank 12.5:1
Glad those parts worked out for you!
I have a set of the custom short pistons here I need to get rid of if you know anyone 87.25mm bore for ap1 rods/ap2 crank. Comes with light weight pins and oem honda rings.
Originally Posted by jaundice' timestamp='1373076308' post='22649732
[quote name='wadzii' timestamp='1373066202' post='22649522']
[/quote]
Thanks. That CR is too high for my supercharged racecar.
I bored a block to see where the FRM completely ran out and got into the aluminum.. that was at 89.91mm
I imagine you'd be ok at 88.. no idea how thick frm needs to be to still maintain its strength
When I catch em during a production run I can get any other bore size made for a small upcharge.
I did just get in a set of 87.5mm +6cc pistons for stock, and I still have the custom 87.25mm short pistons at +6cc
Bump for answers. These pistons are listed at 8.9 compression for a f20c and 9.6 for a f22c but what about if used with an k24 crank in a f20. I'm guessing it will be well over 10.0:1 compression?
