Mase Engineering 6262B Build Thread
Looks good man.
On the Mishimoto fans, I just cut the connectors supplied with the fans and put spay connectors on them and they plug right into the factory plug. Thats what I did and it worked great. These fans sound sweet too and move a ton of air btw.
Looks good man.
This looks real good, so what is the plan 20psi?
So this is the complete list of the outstanding tasks that I need/want to complete
Remaining Items:
Pick Up the Intercooler Piping from the Welder
Attach Fender Liner
Install Bumper
Evacuate AC Lines
Fill Fluids
Bleed Coolant System
Run Vacuum Lines
Wire In new Radiator Fans
Finish Boost Solenoid Wiring
Finish Wideband Wiring
Retorque Head (Verify this is required)
Retune
Calibrate the Map Sensor
Leak Check, Oil, Exhaust, Coolant…..
Program Serial Gauge
Make Intake For Filter
Install Permanent ECM USB Connector
Reinstall Interior Panels
Weld In Cutout
Buy Manual Boost Controller for Cutout
Fabricate Heat Shield for Down Pipe
Check Motor Mounts
Organize my S2000 Manual
Take Pictures and post journal of build
Get the Ignition Systems Ready (Modifying Wiring w/ Capacitors)
Dyno Testing:
AP1 vs. AP2 Cams
COP vs. LS Coils
Factory Cat Back vs. Asura
Cutout vs. Dump to Atmosphere
Open Dump Tube vs. Recirculated
Tuning Testing
Boost Control
Wastegate Feed Back Control
Decrease Spool Time
AFR Feedback Fine Tuning
Fuel and Timing Trims
Intake Air Temp
Coolant Temp
Barometric Pressure
Knock Feedback Tuning
Remaining Items:
Attach Fender Liner
Install Bumper
Evacuate AC Lines
Fill Fluids
Run Vacuum Lines
Retune
Weld In Cutout
Check Motor Mounts
Dyno Testing:
AP1 vs. AP2 Cams
COP vs. LS Coils
Tuning Testing
Boost Control
Decrease Spool Time
Intake Air Temp
Coolant Temp
Barometric Pressure
Well, I got the car running early in the week and planned on finishing it up on Thurday night but I got a call from a local member that was stuck on the side of the road with after firing up his new turbo build. Long story short he reversed the oil relocation lines and the motor starved for oil. I was able to find that the timing gear bolt sheared due the cams being welded to the bearings. Luckly I had a new top end and replaced all of it and got him running again.
So yesterday I put the front end on and checked all the bolts, fittings and conections one last time and all was well. I put my wife in the drivers seat while I spit polished the tune and drove it about 10miles on the highway under 4000 rpm to IloveMyHonda1984's house to get some dinner. On the way back the car was very sluggish and slow to respond. I was monitoring the temperatures and AFR's and there was not problems so I did not pull over. When I got to my house the manifold was blued like I had been racing and it was very hot. So hot the air filter had started to melt. I pulled it off and check the impeller wheel on the turbo and it was SEIZED. WTF.
There should be no problems, the turbo was primed before starting, I had check the shaft play and verified the wheels moved freely w/o touching the housing, I definaly never hit the turbine shaft, there was not oil light so there was pressure, I pulled the oil feed and cranked the motor and it had plenty of flow, the drian line is a -10 AN that when straight down to the pan. This is a brand new 6262 with cermanic bearings it is suposed to be bullet proof.
I only have 10 days left before Mase comes to town and now I am F'd.
