Mase Engineering S2000 Turbo Kit Introduction
Originally Posted by jwa4378,Aug 26 2009, 04:17 PM
3 quick questions... For interested parties...
1) How is the Precision warranty affected (if at all) by not running coolant through the cartridge?
2) How close is the downpipe to the AC lines? Any insulation required (noticed the head shield does not cover the AC lines near the passenger strut tower)?
3) If the OPS "dummy" sensor had been disabled, how will you know if you have low oil pressure? There is no sensor to output to the EMS (stock configuration, or course)...
John
John
2. The heat shield in the picture is not the heat shield that is included in the kit. Further Heat Wrap is supplied for those AC Lines, and do need shielding from heat.
3. The "dummy" sensor has not been disabled. Its the vtec pressure switch.
Originally Posted by berlinas2k2,Aug 26 2009, 11:10 AM
You are going to offer your manifolds with a coating of some type?
Over the past several years, Ive watched mixed reviews on coatings. Some have very good reviews, while others have poor reviews.
The coatings tend to flake off over time, from what ive seen, some of this has to do with the weather/geographical conditions of each user.
Originally Posted by MaseEngineering,Aug 27 2009, 05:06 AM
Most likely, NO. However, if i customer insists, I will be happy to ship the item(s) to which ever coating mfg they choose.
Originally Posted by s2000442,Aug 27 2009, 06:11 AM
So the supplied turbo is not ball bearing turbo? Are water cooled ball bearing turbos better than the supplied turbo? Why did you choose these turbos?
Some people prefer the ball bearing turbos, they will spool faster, however at an added expense. You do have to run the water lines on the ball bearing turbos if you want to keep the precision warranty.
These 5857's are very similar to the gt30 variant, but with the new billet compressor wheel technology.
So the testing you about to do will be with a GT30 equivalent turbo? If that is the case the numbers will definitely fall short of what those of us produced with 35rs. Doesn't sound like there will be a fair comparison.
Ive already done testing and know what the engine will produce with: 5857, gt3076r, gt3582r. And we are about to know what a billet 6262 bb will do.
