Mase Manifold Issue
i shaved it down enough so that it does not touch. The bottom half of the bolt is almost flat. when i shaine a light from the bottom i can now barely see light between the manifold and the tct bolt.
i also recoment you run double gaskets so it will space the manifold out a little
id pull the mani off and give it a healthy dose of some heat in the area where it touches then whap it with a round ball peen hammer. a tiny divot will not effect your flow and is alot better than shaving down bolts and 2 gaskets.
Soul Coughing
Aug 30, 2007 05:19 PM
