Maximum psi
Old Aug 9, 2005 | 06:02 AM
MickeS2K's Avatar
Default Maximum psi
I wonder if anyone can explain to me why Vortech V-2 SC Trim
can produce 20 psi on their spec. But when you put on a 3.8 inch
pulley you max the imp speed and only get 14 psi at 9000 rpm.
Old Aug 9, 2005 | 06:08 AM
Sideways's Avatar
Where did you get that 14 psi information? This is with a larger than 3.8 inch pulley and shows more than 14 psi on an S2000.
If set up correctly you should be able to reach above 14 psi.
Old Aug 9, 2005 | 06:42 AM
MickeS2K's Avatar
How do you get 20 psi? Their spec says that 14 psi at 9000rpm with 3.8 pulley reach 51158 comp.speed.
Old Aug 9, 2005 | 01:40 PM
AusS2000's Avatar
There is more to pressure than just a pump. You also need a restriction. A blower that can produce 20psi on some low revving asthmatic engine will register a lot less on a high revving free breathing F20C.
ssgray22
Feb 23, 2014 06:08 AM
s2konroids
Apr 11, 2012 03:51 AM
Wydget
Dec 23, 2011 01:53 PM
sirguy01
Oct 8, 2008 04:47 PM
dave22
Jan 24, 2005 06:53 AM
