Maximum psi
I wonder if anyone can explain to me why Vortech V-2 SC Trim
can produce 20 psi on their spec. But when you put on a 3.8 inch
pulley you max the imp speed and only get 14 psi at 9000 rpm.
If set up correctly you should be able to reach above 14 psi.
There is more to pressure than just a pump. You also need a restriction. A blower that can produce 20psi on some low revving asthmatic engine will register a lot less on a high revving free breathing F20C.
Wydget
Dec 23, 2011 01:53 PM
