My 1st shakdown run with charger 12.8@112
Old May 26, 2007 | 09:48 AM
bc02's Avatar
Default My 1st shakdown run with charger 12.8@112
Just want some input on how much faster i can expect out of my current setup when i get everything ironed out.
Finally got my charger tuned and it was running pig rich last night at the drags somewhere around 11.2 to 1 at redline....85 degree heat and humidity
I was running on a known slow track at 1200 ft. elevation and the best i could do was 12.80 @112 with a 2.05 60 ft. on my 35 series/18 inch Volks
Traction is impossible but i am not going to run slicks.
Boost hit 12.5 psi @8500 and my tuner pulled almost 30 degrees of timeing out of it on the top end to kill the knock that the AEM was starting to pick up.....it runs fantastic and i have never heard it detonate on pump fuel yet.....the last time it was on the dyno the belt was slipping and it only held 6 psi to the tune of 314 HP and 193 TQ......once i changed the pulley and tightened the belt we finished tuneing it on the street so i don't have peak numbers yet.....i have a feeling its just way too rich right now.....but my tuner said its needed to keep the knock down on the stock compression....i am not putting a thicker head gasket on it
My current setup is in my sig. below
Old May 26, 2007 | 10:02 AM
bigmos2k's Avatar
not bad!! looks real nice!
Old May 26, 2007 | 10:08 AM
AirborneS2K's Avatar
314hp 193 tq to the wheels and a 12.8 without slicks, is that considered avg with the 4.56 gears in? I do have a question for you though, whats with the ridiculous amount of guages?
And your breaks are nice.
Old May 26, 2007 | 10:14 AM
Rxmfn7's Avatar
Hey I saw you at the track last night, i was the one with the bone stock silver S2k there (14.7@95 haha). Nice car! You car is running almost idential times as I was in my FD with ~300RWHP and 285/30r18 tires. With some ET streets you should be able to pull low 11s, but as far as on steet 18s, your maxing it out. More power is just going to inflate your traps, not your ET.
Old May 26, 2007 | 10:31 AM
bc02's Avatar
the 314 Hp was only at 6psi.......its making 12.5 psi now with a 3.15 inch pully
as far as the gagues.......i just love DEFI BF gages! don't ask
Rxmfn7......i didn't see your ap1 there until you ran in qualifing.....you made quick 16 all motor didn't you?? what place did you qualify in??
don't forget that FWD cars are way lighter than our S2k's....my buddy went 11.8 @121 last night with only 285 hp.
Old May 26, 2007 | 10:35 AM
Rxmfn7's Avatar
Not sure what place I qualified in, I got a phone call and had to leave after my 2nd qualifying run. There were some quick cars there last night though, I just need to dump some money into my S, its slowness depresses me
Old May 26, 2007 | 10:42 AM
Dsgs2k3's Avatar
your tuner pulled 30* of timing out of your car thats alot
Old May 26, 2007 | 10:43 AM
bc02's Avatar
Rxmfn7......were meeting sunday for a little cruise hope you can join us in the future with the Allegheny club.....just check the board for the latest info.
Old May 26, 2007 | 10:45 AM
bc02's Avatar
Dsgs2k3......when it was all motor he advanced the timing from stock to gain more power and it worked.....but now that it is blown he had to pull the timeing way back everywhere and especially on top end because i am running so much boost on the stock compression
jdmz
Feb 21, 2019 08:20 AM
LordSovereign
Mar 18, 2015 08:03 AM
JoeyBalls
Apr 5, 2011 08:55 AM
JoeyBalls
Sep 14, 2008 07:32 AM
bc02
May 17, 2007 11:20 AM
