Need Help W/ Supercharger
Old Nov 12, 2010 | 05:18 AM
  #41
MugenRioS2k's Avatar
Mike at FactorX says that the EMU is not fast enough to handle this function. Is this true? I don't have PLX only an AEM will this work?
Has FactorX clocked the CPU speed of the ULT I highly doubt that; with out that exact info there is no way to say that it is to slow..
I have been using A/F feedback for over 3 years now with no issues.
However the misconception is you can use the A/F feedback to build your basemap fuel curves. This is totally incorrect and will blow the motor up.
The A/F feedback just keeps the A/f where it should be for changes in environmental conditions after the base fuel curves have been generated on a dyno.
This is exactly the same process the OEM PCM goes through when operating in open loop.
Yes the AEM will work just set the A/F option as "other" and select the range in AF in the ULT.
Old Nov 12, 2010 | 05:22 AM
  #42
Originally Posted by K-Lo,Nov 11 2010, 09:33 PM
But you yourself said you're comfortable with the EMU up to 15psi which is close to mine.
I have tuned cars to higher psi than that however above that level I like to have added features as failsafe to protect the motor incase the owner does something stupid like just randomly turn up the boost another 15psi without informing me...
I had some1 do that. POP goes the weasel or more correctly a rod; rank shaft; head gasket; starter…ect. Was not a S2000 it was a 350Z
Old Nov 12, 2010 | 07:50 AM
  #43
K-Lo's Avatar
Probably not, i've opened this idea to FactorX before but he suggested going standalone because of the reasons he stated. Perhaps he was just pushing me to get a standalone. Anyway I don't want to threadjack, thanks for the info mang, kinda gave me good prospect with my EMU. I'll shop around for the Greddy 15900912 harness.
Moddiction
Mar 12, 2014 06:26 PM
Fizoust
Feb 11, 2013 07:43 AM
modMonkey
Sep 26, 2007 04:01 PM
overlord
Oct 6, 2006 03:15 PM
hukares
Dec 12, 2005 10:07 AM
