Need some help, misfire at VTEC point...
Old Aug 30, 2013 | 12:23 PM
philistine's Avatar
Just sharing my story which lasted about 9months until final solution:
I had a lot of problems with vtec transition during tuning. There was a lot of pop/farting and drop in power. 3 tuners from completely different shops had a crack at it. One said...misfiring, the other said vtec solenoid is bad. Finally, in the end an expert was called in (Mike from OSTdyno), changed the plugs to NGK BKR8EIX, gapped the Iridiums to 0.023", set the vtec at 7k rpm and adjusted the fuel maps for the high cam - 3hrs done!
Before any of that I heard my engine was toast etc. Leak down tests, compression test and even removing the heads proved the engine was in perfect condition. Right now it runs better than ever - Hondata Kpro III, Inline pro stage 1 w/log style manifold.
Old Aug 30, 2013 | 05:44 PM
wadzii's Avatar
Banned
That sounds like it just took 3 tries to find a competent tuner, glad you got it worked out
Old Aug 31, 2013 | 10:36 AM
B5254T4's Avatar
Originally Posted by wadzii
I can get you to about 10.5:1 w/the turbo pistons
Do you guys run a 2 liter or 2.2liter crank?
I have 10.5:1 now with your pistons and the machined head but would be great if they made a stock compression piston since a lot of people here like to run high comp.
Real men run 2.0. Most of us do. BTW, were did you post the sponsor stuff? Here in FI?
philistine: Will try 8´s, used them on my own car and everything worked perfect from start. Thanks.
Old Sep 7, 2013 | 10:19 PM
B5254T4's Avatar
Did a compression test and got numbers good enough for a new engine. Do you guys know if they show good compression even if the ring lands are bad?
Old Sep 7, 2013 | 11:55 PM
s2k manic's Avatar
I would say if a leak down test looks good then I would run it at least you will know if the pistons are scuffed or rings bad see if you can pickup a bore scope I have one Milwaukee makes has lcd screen with a camera that has attachment's to look at the combustion chambers. what were the compression test numbers? I take it you had the throttle open fuel pump fuse pulled good luck to you let us know
Old Sep 8, 2013 | 11:02 AM
B5254T4's Avatar
No leak down stuff around right now but made 230psi on all four with a brand new compression tester and checked it with camera a few days ago, can´t see anything wrong. Tested with both closed and open throttle, same numbers.
Changed to NGK 8´s and coils from my own car and it ran a bit better but still problems at VTEC point.
Since she only gives me problems at VTEC she´s fast up to 7000rpm, maybe a good idea to set the rev limit there as well?
Old Sep 8, 2013 | 11:05 AM
wadzii's Avatar
Banned
Unbolt the exhaust and take the air filter off and see what happens
Old Sep 8, 2013 | 11:13 AM
B5254T4's Avatar
Tried the exhaust but filter is interesting, thanks!
Don´t know if you read my question a few posts ago, did you post your sponsor stuff here i FI? A lot of engine maniacs here.
ninjas r everywhere
Mar 5, 2014 06:32 AM
crb5885
Apr 15, 2013 12:17 AM
sarge1
Jul 30, 2011 03:17 PM
batikan
May 16, 2008 04:53 AM
Hobbyholic
Jan 19, 2005 05:28 PM
