New Fans
To make a shrouded radiator work properly you MUST have both fans turn on at the same time.
Other wise when one turns on only about 10-50% of the air being pulled by that single fan is actually being pulled through the radiator; the rest of the air is being pulled backwards through the other fan even if it is not spinning in the opposite direction due to air being pulled backwards through it..
Unless the shroud is divided.
Originally Posted by jaundice,Aug 10 2010, 04:33 PM
Thats the same place I got mine, but I just dumped the Mishi fans and shrouds for the SPAL fans.
actually now i think im going to start with the spal fans
changing radiators doesnt directly lower any temps does it?
Originally Posted by wait4vtec,Aug 10 2010, 04:39 PM
i just want to get more air moving, which will cool my temps a little
Larger radiator will have a lower equilibrium point and will take longer to reach this point due to larger thermal mass and increased heat rejection but again the thermostat is the main controller of your steady state temperatures in side of the block.
Originally Posted by wait4vtec,Aug 10 2010, 04:40 PM
is it the way you wire them up for them both to run or is it in the AEM or both?
Or if you understand diodes you can have both relays turn on by either the fan switch or the AEM but have that signal isolated so it will not feed back in the AEM.
There are multiple ways to wire them up to use the AEM features to get them to both turn on at the same time.
im trying to figure out what will fit my setup best
wheather its getting mishimoto radiator/fans
or just keep stock radiator and go with spal fans
with ethier of these set ups will there be more or less clearance then there is now with the stock fan/radiator between it sand ic piping?
please let me know what yall think!
