New supercharger kit
Old Nov 18, 2006 | 05:17 PM
  #161
Balthazar_B's Avatar
Any word on CARB-certified versions in the works. Or in the case of Jackson will that be never?
Old Nov 18, 2006 | 05:23 PM
  #162
billyjoho's Avatar
Originally Posted by slimjim8201,Nov 18 2006, 04:25 PM
There are many differences between the compressors used in the Rotrex systems and the centrifugal systems. Centrifugal compressors are designed to operatate at MUCH lower operating speeds, as there is a limit to how fast the pulley/gear drives can efficiently spin them. For this reason, they have completely different impeller designs and considerable larger housings designed to move more air at a lower operating point.
Turbocharger compressors spin at 2-4 times the speed of most centrifugal compressors. Their compressor housings are a lot smaller for this reason. 500 CFM from a small compressor spinning at 150,000 RPM isn't very different than 500 CFM from a large compressor spinning at 50,000 RPM. The fact that the Rotrex drive spins much faster is not the cause of the more desirable boost curve. That curve is directly related to the fact that the blower speed is not held at a constant ratio relative to engine speed.
If this kit is making only 300 whp at 10 psi, I'd be pretty dissapointed. That must be a misquote.
You are correct and are very knowledgeable when it comes to turbos and superchargers. I can assure you guys that the goal here is to be north of 300 HP...even with the 5 psi kit. I can tell you we expect it to be north of 400 HP on the 10+ psi in my S2000 but until we are finished testing and tuning and do some dyno pulls we are only hoping and wishing right now
Old Nov 18, 2006 | 08:36 PM
  #163
jakub2000's Avatar
the only thing that stops me from killing my self and not have waited for this is the fact that I will be hitting the dyno with 16psi tomorrow on my reworked turbo set up. Otherwise I would just hold on to my NA components I had (header, single exhaust ect.) and get this.
I think 300whp @ 10psi is underrated even tho this blower is not as huge as the Vortech. Plus keep in mind you can still make more power by adding a J's Racing header and 70mm single exhaust.
Old Nov 19, 2006 | 11:06 AM
  #164
ryu_2k3's Avatar
I must admit that i belong to "daily-driver friendly" group. MPG is a concern. Even if it's a miniscule one, it's still a concern I factor in. Can anyone speculate on any MPG effects for this JR Rotrex?
Obviously, your mileage will vary but in general i'm hoping someone can help a FI noob with some MPG estimates.
Old Nov 19, 2006 | 11:50 AM
  #165
NFRs2000NYC's Avatar
IN my experience, as long as you keep your right foot light on the throttle, your MPG should be as good as stock, or 1-2mpg worse. You wont be dipping into the single digits if thats what you are worried about.
Old Nov 19, 2006 | 12:33 PM
  #166
elusiv's Avatar
If you're making full boost by 1800-2000 rpm, wouldnt that lower mpg drastically?
Driving around constantly at 10psi constantly should make more of a difference than 1-2mpg, or so I thought?
Old Nov 19, 2006 | 01:24 PM
  #167
MugenRioS2k's Avatar
Being that the TB is places after the compressor and there is a blow off/pop off valve there is still a bit of parasitic drag just like a Comptech or Vortech system.
However despite having the blow off/ pop off valve with the JR setup I would assume there would be more drag when out of the throttle due to the speed of the turbine and the head pressure on the out put side. All though its is probably not that much more then the Vortech or the Comptech systems.
Old Nov 19, 2006 | 02:22 PM
  #168
SilentWhiteNoise's Avatar
If the SC is making ful boost by 2000 rpm.. that means there is alot more force all through out the entire RPM range. Much more wear and tear then making full boost by say 5000 rpm. So does that mean that the engine will wear out that much faster? Just curious if my logic is correct. Personally... If some one were to complain about a 2.2L making 300 whp that "only lasted 95,000 miles" I would say their crazy. Thats a crapload of power from a tiny engine. Allthough technology is making this a fun game of how much power you can make with a tiny engine!!
Old Nov 19, 2006 | 02:43 PM
  #169
The issue /concern with increased engine wear when the engine has been boosted has been discussed multiple time search the FI forum.
Old Nov 19, 2006 | 05:24 PM
  #170
ryu_2k3's Avatar
a 5-10% decrease is acceptable for me! once we start going into 4-5+ in MPG loss then it wouldn't be such an easy decision to make.
On a different note, i'm hoping the inertia from the Rotrex spinning doesn't cause the RPM to hang too long after lifting off the gas pedal. This is probably a non-issue and my guess is it probably has an opposite effect due to parasitic drag.
*eagerly awaits*
