Nitrous
Old Jul 23, 2007 | 10:29 AM
fit4897's Avatar
Default Nitrous
I am thinking about running some nitrous, what is a safe shot to use. WET or DRY shot. 50 or 75 shot. many people are telling me diferent things. i was wondering if there is anyone out there that has done this already and can help me as to what setup is safe to run. with a good tune of course. thanks
Old Jul 23, 2007 | 10:51 AM
Sinji's Avatar
wet system is always better and if you want the max power use 75 shot but I would suggest you use 50
also get colder sparkplugs
Old Jul 23, 2007 | 11:02 AM
s2kminator's Avatar
true wet shot is always better
Old Jul 23, 2007 | 12:14 PM
weiRtech's Avatar
i had a wet setup that i did on another car years ago. you will want to retard your timing a bit, you should also look into upgrading your clutch if it is stock... mine burned out pretty quick. make sure it is installed properly!
Old Jul 23, 2007 | 01:41 PM
s2k dre's Avatar
im sure the timing on a stock S isnt that agressive, 75 wet shot with 93 octane will be safe. anything higher will need the timing retarded.
Old Jul 23, 2007 | 01:42 PM
Nyther's Avatar
I'm running a ZEX 55HP dry shot, we got 98 octane also here.. ( europe )
Old Jul 23, 2007 | 02:45 PM
Dark's Avatar
dry shots are stupid. not only do you make more power with a wet setup but its also that much safer on the motor.
though zex does overrate their kits so a 55 shot is probably closer to a 35
Old Jul 23, 2007 | 02:53 PM
gerdaland's Avatar
i heard 110 shot on 110 octaine, not from personal experience though
Old Jul 23, 2007 | 02:54 PM
Nyther's Avatar
zex increases fuel pressure also under nitrous shots, and yes, i calculated the 55HP jet setting and they would be around 40HP instead of 55HP. but thats ok for me
TurboCongo
Jul 22, 2008 08:22 PM
street_ruler
Jan 7, 2008 04:40 PM
tampas2000
Jan 31, 2007 09:48 AM
TwiztedS2K
Jul 9, 2005 06:33 AM
johnR
Jun 26, 2001 03:54 PM
