No spark
Old Oct 21, 2012 | 08:45 AM
  #21
Reapur's Avatar
When you have a no spark situation the logical starting point would be the ignition system and work your way back from the obvious to the obscure. Not he other way around.
That rule of thumb applies to anything when problem solving.
Old Oct 21, 2012 | 12:48 PM
  #22
AusS2000's Avatar
When you have an AEM ECU that is known to be flakey vs. the possibility of multiple coils failing simultaneously I'm not sure which end is the more logical.
Old Oct 21, 2012 | 12:57 PM
  #23
s2knoob89's Avatar
All 4 coils going bad at once... Happens all the time
Old Oct 21, 2012 | 04:30 PM
  #24
Reapur's Avatar
While your at it, buy a AEM series 2 or maybe a Haltech since you're an Ausie!
Old Oct 22, 2012 | 01:18 PM
  #25
InductionPerformance's Avatar
Originally Posted by AusS2000
Seems InductionPerformance wins the prize. Looks like it was coils after all.
I got the laptop connected and it was finding sync so that eliminates that possibility. I then swapped coil 1 for one of my spares and on turning over it coughed and spluttered a bit. So I replaced coils 2 to 4 with my old spares and it started reasonably well. Guess it was a bit flooded from all the false starts.
Anyway the coils I had lying around were from my old motor and were a bit fire damaged and messed up but at least they start the car. Might shop now for soem newbies.
Thanks for all your help guys.
Glad you got it figured out.
Old Oct 22, 2012 | 01:50 PM
  #26
s2kt3's Avatar
6 days ago that advice would have been most helpful.
I gave you that advice more then 6 days ago .....
Originally Posted by s2kt3' timestamp='1350604629' post='22093532
why dont you diagnose it ......
I thought that was what I was doing.
Perhaps my lack of pace is confusing you. I do have a job.
step 3 in what i told you to do .... replace coils with good known................. I laid it out for you, it should haven taken 15 minutes ... so your job has nothing to do with anything ......................
I was honestly trying to help you... and I would have led you in the right direction instantly (being a veteran honda technician and all)
glad its fixed. now go shred some tires off !!!! hahah
-Lee
Old Oct 22, 2012 | 11:44 PM
  #27
AusS2000's Avatar
Received some new coils today. Put them in and started first time.
Old Oct 23, 2012 | 05:00 PM
  #28
s2kt3's Avatar
goood stuff !!!!
Old Oct 23, 2012 | 10:49 PM
  #29
s2000Junky's Avatar
As long as the coil drivers in the aem ecu dont burn out your next set of coils anytime soon.
Old Oct 24, 2012 | 05:34 AM
  #30
tuner's Avatar
An AEM EMS for the S2000 (1052 and 6052) isn't using coil "drivers" to fire the coils. The EMS in this application is simply sending a 0-5V falling edge trigger to the S2000 OEM coils that have built-in ignitors.
An end user commanding too much dwell (over charging the coil), higher than stock demands, increased engine bay temps, etc. are some of the factors that can contribute to coil failure.
AusS2000
Dec 29, 2014 01:49 AM
CR1S
May 13, 2014 10:58 AM
s2kseven
Nov 6, 2012 08:17 AM
ECU Pirate
Dec 30, 2008 01:49 AM
paulsaunders
May 26, 2008 05:10 AM
