THE OFFICIAL: WATER/METHANOL INJECTION Thread
Old Jun 9, 2011 | 05:31 PM
  #161
siadam's Avatar
Originally Posted by RealStreet
Are the guys on this board that are using the AEM 30-3000 kit. Are you use the standard 550ml/min nozzle? If so how much power have you seen from it and what mixture do you use?
Made 650whp on the single nozzle before I lost a cylinder.
Keep it under 600whp and you'll be fine.
Sent from my iPhone 4 using Tapatalk.
Old Jan 6, 2013 | 10:25 AM
  #162
S2Kitt's Avatar
Is anyone running Meth on the SOS Kit or any other SC setup?? just curious, been seeking different avenues to gain a lil more power out of my Supercharger.
Old Jan 6, 2013 | 12:12 PM
  #163
s2000442's Avatar
Personally I would not go this route. There have been a lot of engines that have popped with this setup at higher hp levels. It's critical it appears to have proper atomization and preferably direct port injection. Even then it can be un reliable. If you want more power stick with race gas or E85. Eternalx motor was apparently shot after running meth and he has now sold the car.
Old Jan 6, 2013 | 03:43 PM
  #164
s2000Junky's Avatar
Yes there is.
Old Jan 6, 2013 | 04:02 PM
  #165
S2Kitt's Avatar
Originally Posted by s2000Junky
Yes there is.
I take you are running this, how do you like it? what kind of numbers are you making and what gains did you get from running Meth?
Old Jan 6, 2013 | 04:06 PM
  #166
s2000Junky's Avatar
Originally Posted by s2000Junky' timestamp='1357519399' post='22249541
[quote name='S2Kitt' timestamp='1357500323' post='22249080']
Yes there is.
[/quote]
Everything you need to know is in this thread. Check it out, if you still have specific questions then shoot away
Old Jan 9, 2013 | 06:50 AM
  #167
justinsan's Avatar
I have a vortech sc kit from a 2005 that I'm putting on my 2008 s2000. This kit has a 5th injector on the aftercooler. Since I have no need for the fifth injector, I was wondering if i can utilize this as the injection point for methanol? Would it be efficient in this area?
Old Jan 10, 2013 | 10:49 PM
  #168
s2000Junky's Avatar
Yes it will be effective there, assuming you adapt the meth injector to fit. The typical thing done with a single port system like this is to just drill and tap the intake elbow or aftercooler, so your already a step ahead.
Old Jan 11, 2013 | 03:50 PM
  #169
p0staboy's Avatar
I wanted to do direct port 100% meth this season but my tuner told me he highly does not recommend it as it's not safe and he's seen a lot of engine fires related to to using 100% meth
Only other option for more power is race gas but it's so damnn expensive
Old Jan 13, 2013 | 05:40 AM
  #170
s2k manic's Avatar
i want to throw this out there i've been using water meth for the last 8 years on my diesel truck and 1 year on the s i notice if i haven't driven either in awhile the system lags a bit so i will go into boost in a higher gear to prime it without worrying i will lean out just curious if anyone else notices this?
