THE OFFICIAL: WATER/METHANOL INJECTION Thread
has anyone run the Meth-kit on a N/A motor? I get what it does for FI, just wondering if there would be any gains on a Mild N/A build. Snow Performance makes a pretty nice kit for N/A. Just trying to do a lil research before jumping into anything.
If your racing your car, I could see a slight benefit to the cooling attributes of the injection in an N/A motor, where higher AIT heat could be a factor. But not as a means of increasing power, just better maintaining the power you have from heat soak.
I posted this on another thread and thought it would be more appropriate on this thread.
Its basically about pre-turbo water injection by using ALL MECHANICAL METHODS. No pump, so no failers.
"I don't know if I agree with your theory. There are many people in AUSI land that DUMP IN water. I mean 1200-1500 cc of water into there motors and make REDICULOUS power.
Here have a good read.
http://www.rx7club.c...water+injection
Its all about getting the atomization.
Here is some more reading about pre-turbo injection as well.
RX7 boys have been doing this for years. I have installed it on one car, an evo, and it really does push the compressor map. WILD stuff. Kills detonation as well. I LOVE WATER. DID I MENTION ITS FREE?
Yes, in the US it is used on rotary's. That community has embraced it. In the rest of the world, its not really used on rotaries, so help me understand what your rant about piston vs rotary motors was again. :-)
Originally Posted by s2000Junky' timestamp='1305088620' post='20562029
[quote name='flexer' timestamp='1305033558' post='20558297']
[/quote]
As someone that uses water/meth for some time and is familiar with its strengths and weaknesses. Simply saying that a guy with a rotary motor is having great success injecting 1600cc of water into his motor therefore it can be done on any type of engine/set up... is not something I agree with. For example, A triangle piston that spins has a different sealing capability and use of materials (ie apex seal) completely different design then a piston engine, which I believe to be much more sensitive to washing of the cylinders, especially when injecting a 100% non combustible liquid into the combustion chamber. I want to see how much traction you gain if you start preaching to people in this thread that the OP would have been successful if he simply injected 4x400cc injectors into his i-4 with 100% water. Or even a single 1600cc injector Pre TB. My point is, if your going to disagree with my position that’s fine, but back it up with something that is at least relatable. As I said, there are numerous variables that will dictate success or failure with this type of injection and there is no one right way for all. Just the right way for that particular application. One thing I agree on is that atomization is extremely important, no matter what fluid used or motor and set up.
Originally Posted by flexer' timestamp='1305137363' post='20564245
[quote name='s2000Junky' timestamp='1305088620' post='20562029']
[/quote]
[/quote]
No one is disagreeing with anything other than I don't believe your reading my posts. I told you this was not about rotaries above, and now here we are again with you preaching about the difference between rotaries again. WOW is all I can say. I would go back and quote my exact messages, but I don't think it would matter. Its like a reading disconnect we got going on or something??!
Do I need to write in caps. Fine then: THIS IS MAINLY USED IN AUSTRALIA ON PISTON MOTORS, but only the rx7 forum in the USA seems to have started embracing it here in the US. I installed this setup ON A EVO and had GREAT success with it.
Wait, are you going to reply to my thread now about how an evo has a rotary motor? :-)
