Oil feed
Old Feb 26, 2013 | 03:29 AM
Corey Maurer's Avatar
wher di you find a steel T?! I cant seem to find one in 1/8 BSP?! Its driving me insane lol I think just an 1/8 NSP male with a a 1/8 BSP female and a -4 Male is what would work best for me! yanking my hair out searching for one
Old Feb 26, 2013 | 05:22 AM
s2knoob89's Avatar
http://www.brfittings.com/index.php?...&product_id=93
Old Feb 26, 2013 | 05:27 AM
herecomesboost's Avatar
Originally Posted by redboost10
plug the vtec oil switch, you dont want to use this oil port for turbo feed because of the fluctuating pressure to the head.
True. I overestimated the oil pressure at this location on my previous setup
as for the block where the oem oil pressure sensor is, you can use that for a oil feed, but id think you want some sort of oil pressure gauge in the car?
I agree with this as well. Using the oil pressure sensor, (the one directly below the vtec solenoid/pressure switch) while not required, is probably a good idea. Are you (Corey) running an aftermarket oil pressure gauge?
Old Feb 26, 2013 | 06:07 AM
passmans2kny's Avatar
I run mine off the block to a t for my oil pressure gauge
Old Feb 26, 2013 | 12:34 PM
camuman's Avatar
Fullblown uses this method. the stock oil pressure switch is a dummy light when the oil is stupid low. its worthless. this is a great place for an oil feed. if you dont check your oil often, then why turbo your car.
Old Feb 26, 2013 | 01:01 PM
Phill24's Avatar
Theres a place down here called morland hose..they have every fitting know to man
Old Feb 26, 2013 | 01:57 PM
d-bo's Avatar
i left the oem one alone under the vtec solenoid incase i need it for when i have to put all my stock stuff back in for inspection (love nys)
running a sandwich plate adapter that i purchased on ebay for my feed, and my oil pressure gauge. they have all different colors, but you can also powder coat it too probably. it was like 25bucks
Old Feb 26, 2013 | 04:53 PM
Andrew Wojteczko's Avatar
I'm using a 1/8 bspt fitting in the block where the factory oil pressure sensor was to a remote mounted -4 male in and -4 male out tee with a 1/8npt female port on the branch from bat inc. Aem pressure sensor in there and then the -4 out to the turbo oil feed. I wouldn't be comfortable hangin anything off the bspt port on the block, and remote mounting pressure sensors is good practice anyways.
Old Feb 26, 2013 | 09:47 PM
tx2K's Avatar
Ill be running a line from the block to a T with a port for a pressure gauge.
Old Feb 26, 2013 | 11:45 PM
Phill24's Avatar
Jump the connector for the vtec pressure switch and dont hit vtec..light wont come on...thats how i have mine set
#1turbos2k
Nov 6, 2015 12:59 PM
Calzonii
Nov 1, 2015 02:07 AM
08s2000CRbackinblack
Jan 30, 2014 08:45 AM
MrC@PTUNING
Oct 16, 2012 09:49 AM
GoTuningTommy
Jul 28, 2006 10:38 PM
