Oil filter relocation
Old May 31, 2008 | 11:09 PM
blueap2's Avatar
Default Oil filter relocation
Do I have to remove the factory oil cooler with the Canton Racing oil filter relocation kit?
My setup will consist of a full-race manifold and a gt30. Im gonna start my build in a couple of weeks so any help would be greatly appreciated...
Old May 31, 2008 | 11:33 PM
cash84's Avatar
in order to use the canton racing with that full race manifold, you must remove the water cooler but you have to get a full race relocation kit or email what part # for that banjo bolt. You can reuse the water cooler or convert it over to a air cooler (which is what I did). And do yourself a favor relocate the fuse box inside the fender or make a heatshield. I found out part of my fuse box melted and wires also abit. I would like to put that out so no one else get that problem.
Old Jun 1, 2008 | 05:52 AM
PatS4P's Avatar
Banned
I reused the factory heater/cooler, it is a very efficient unit.
BTW my Canton filter mount was out by .015 hence the machining to true the surface. Just retap with a 22X1.5mm tap(after drilling appropriate sized hole)
Old Jun 1, 2008 | 09:21 AM
TheCarGuy2021's Avatar
You will need this if you don't reuse the factory oil cooler:
It's the oil filter holder off a Civic.
Old Jun 2, 2008 | 02:34 PM
blueap2's Avatar
will i have any problems without the oil cooler?
Old Jun 2, 2008 | 02:56 PM
PatS4P's Avatar
Banned
Your oil will get hot
duhelo
Apr 28, 2016 05:33 AM
dsddcd
Mar 9, 2010 07:56 PM
s2000 or 240sx
Jan 4, 2010 04:54 AM
PeanutButter
Oct 16, 2007 04:37 PM
s2guru
Oct 9, 2007 12:09 AM
