Oil Sandwich Leak
Old Feb 20, 2014 | 02:24 PM
S2KCER's Avatar
Default Oil Sandwich Leak
Hey guys,noticed a small leak where my oil sandwich is from my relocation kit. Any ideas what the cause is? From what I know the only reasons would either be:
1.Not tight enough
2.O Ring busted
3.fittings loose
4.installer didnt apply teflon to fittings
any other reasons that might be causing the issue? its a very tiny leak, but overtime since the car is parked for winter its making a bigger puddle...would like to fix it when i install my oil cooler, any input would be appreciated,dont want to always scrub down the floor lol. cheers fellas!
Old Feb 20, 2014 | 02:50 PM
redboost10's Avatar
Is it coming from where the plate mates on the block or from the fittings?
If it's from the plate itself, it could be either the oring, or bolt not tight, or sometimes I've seen the plate misaligned and not making full contact with the block surface.
Which sandwich plate is it? I believe the Canton one required the bolt to me trimmed down because it would bottom out on the Honda oil filter fitting.
Old Feb 20, 2014 | 02:58 PM
S2KCER's Avatar
I have the the greddy one which came with the turbo kit. havent had time to jack the car up and examine it yet, but will be doing that when i put the oil cooler in. Hence I wanted some opinions on what might be the culprit. such a small part, so many things " could " be wrong lol fml
goldenfri
Jun 7, 2016 06:37 PM
s2konroids
Aug 26, 2013 04:15 AM
david.mt
Jun 25, 2011 12:01 AM
NA_Ted
Jul 15, 2008 10:17 AM
HMFIC
Apr 10, 2008 05:27 PM
