Turbo And oil Filter Problem
Old Jul 13, 2008 | 09:54 PM
NA_Ted's Avatar
Default Turbo And oil Filter Problem
Well, I bought a Revhard manifod and a precision sc61 off a guy who had it on his car. I go to put the kit on knowing it need a filter relocation kit, problem is, there isnt a bit of room to where the plate would fit either!!!!!
any suggestions?
I want to get this done
Old Jul 14, 2008 | 03:45 AM
macprotege5's Avatar
i believe when you install an oil filter relocation kit you replace the factory "plate" you have in the picture. i also believe if you have a water cooled turbo the lines that are attached to the factory plate get routed to the turbo.
Old Jul 14, 2008 | 08:44 AM
Tyraid2K's Avatar
ya im sure the oil cooler comes off, that should give you a lot more room, I relocated my oil filter to the forward beam
Old Jul 15, 2008 | 08:20 AM
gotswap's Avatar
Check out inline pro for the kit, very nice and completely bolt on.
Old Jul 15, 2008 | 10:17 AM
HMFIC's Avatar
WOW!!! old and good times...
ok this is EXACTLY What you do. you have the get a "sandwhich" oil relo kit. basically, you unbolt the bolt that holds the oil cooler to the block. you place the sandwich part to the block, and the new bolt goes through the plate that holds the sandwich part to the block....
You have to get longer hoses for the coolant, and oil lines because your gonna be extending them to the new location. Similar to the inline pro oil relo kit. place the oil cooler on the relocation part, bolt it down with the bolt that you just had taken off from the earlier location, bolt it up to the new plate, hook up the coolant lines, and oil lines, add the oil filter, and VIOLA!!!! your done!
Good luck!
neoleooo
Mar 25, 2013 11:00 PM
otbs2k
Apr 20, 2009 01:46 PM
o'malley_808
Mar 25, 2009 03:31 PM
skibum
Oct 27, 2007 02:56 PM
Diddy
Feb 4, 2004 06:25 PM
