O'Malley's Winter build
The feed to the pass side is the same gauge as the alt wire. When you look at your positive terminal on your battery (oem location/wiring) you will see one pos wire runs to the pass fusebox, the other goes through the firewall and into the wiper channel and over to the drivers side fusebox which uses the same fuses as the pass side fusebox. I think nobody has bothered trying this that's why there's no answers...
Originally Posted by o'malley_808,Dec 31 2010, 11:35 PM
^ Yeah I still havnt finished that far, I don't have a power cable ran from the front to the trunk yet and have not quite decided how I want to connect the positive power cables together yet at the front of the vehicle...hmmm Was thinking maybe a isolated post from summit or maybe a switch but still undecided
I suppose I could just connect it temporarily.
Havn't had a chance to work on the car much more lately. It's absolutely freezing outside and we just got buried! Here is a pic of our American muscle stuck outside in the elements
Wire tuck is 100% complete.
Here is the pass side fender area with the + running to the rear of the car.
Here is the drivers side fusebox mounted in the fender. I ran the wires for the wiper motor and + power source through the windshield wiper well.
I left the fenders off for now. Still have to figure out where I want to mount the boost solenoid which the wires will be hidden. Also have to decide if I am going to tackle a meth kit which the wires will also be hidden...
Yeah looks good passman! I really like the way you fitted the map sensor. This got me thinking about how to configure my boost controller the same way. May configure 2 quick connect fittings right on the firewall with the solenoid hiding in the wiper well thing.
You need to do this quick/easy mod.
From this ..
To this...
Complete writeup here.
https://www.s2ki.com/forums/index.php?showtopic=777540
From this ..
To this...
