Opinions on what should go into a built head.
Yeah, that's who I'm leaning towards to do my sleeves. They seem pretty stout.
What I'm thinking for the bottom end is Pauter X beam rods and CP pistons at 9.6:1 with the stock head gasket which will bring the CR up a little. From what I have heard they rate them with a 1mm head gasket; the stock is smaller.
I wonder how they are at building the complete block and getting it timed right.
Again, I can't express how much I appreciate the help guys.
I wish I knew what the stock spring rates were that way I'd know if 80lbs is stronger than stock but not too strong so as to stretch the valves. I guess I really have no choice hahahaha.
if 100lbs on the seat causes a valve to break you have awayyyy bigger problems than springs that are too stiff.
I have the 100lb springs in my car.. 15k miles on stock valves that already had 100k on em.. no evidence of anything going wrong as of yet.
generally for turbo cars we put as much spring as possible in there.. think about it, each valve is around 1.5 sq in, with 20 psi of boost you are basically reducing the seat pressure by 30lbs, so your 80lb spring is now just a 50lb spring.
