PFab / InlinePRO Custom Turbo Kit Install...
CarGuy - How did you settle on 80 lb/ft for your torque spec on the studs? Assuming you used moly lube? How many times did you torque / re-torque before you settled on the final spec? I have read others (successfully) have done it to 110 lb/ft, while others at OEM spec have not fared so well... I am getting ready to do it myself in a month or so, so I was wondering how you settled on your specifications? (It's hard to determine what is "correct" over the internet sometimes) Also, are you getting your head machined?
SPECOPS - You turn the inner gear as FAR clockwise as it will go. This is done because the raised head deck height changes the cam/valve timing ever so slightly due to the stretched cam timing chain. People have had success doing it and not doing it. I think it is more of a precaution than anything. It is debated on whether it would really even change anything, because the overall change in head height is less than 1 link on the timing chain...
Thanks
John
Thanks
John
Originally Posted by TheCarGuy2021,Dec 28 2007, 11:46 PM
It wasn't too much of a pain to get off and having more room/space to work with was nice. If time is not an issue, I would just do it anyway. I got my head back on today without any problems, I also used ARP head studs torqued to 80 lb/ft.
Putting a rubber band on the orange cam chain guides to hold them together helps when you put the head back on, otherwise it won't go back on when using studs.
The rocker arm assembly is a bugger to get back on, that's where I left off.
Originally Posted by ChefJ,Jan 6 2008, 11:23 AM
I used rubber bands to hold the rocker arms together as opposed to continuously lifting them into place. It helped me save some time and frustration.
It makes sense when you sit and think about what it looks like...
