PFab / InlinePRO Custom Turbo Kit Install...
I realized this after thinking about it, yea when you set TDC the lobes will tell you lol.
Well I know I could not format a base map for anything.. If you want to save some time you could try it how I said. It took me fifteen minutes at the tuner to swap my injectors, and I didnt even use injector clips, I did the DIY zip tie mods somewhere on the forums to hold those bad boys in place..
Hope this helps.
-K
Hope this helps.
-K
Originally Posted by blueap2,Feb 11 2008, 02:02 AM
i spoke to john at inlinepro and he said the oem studs only need to be torqued down to honda specs once only and thats it...
ok, my friend that works at honda and my friend that works at merc said you will always have to retorque after reinstalling head bolts. He also said make sure you clean the bolt hole very well!!!
I can't believe I never noticed this thread. Great work man! I'm assuming that TDC means top dead center or something right? I've never done any engine work before so this is new stuff for me.
I'm doing mine within the next week or three so this will be very very helpful!
Justin
Justin
Justin
Justin
Maybe im seeing this wrong?
-K
