Please Help!
Did you solder you're connections or did you use the lame ass butt connectors vortech gives you?If you did not solder the connections then that is most likely you're problem.If you did solder the connections then you have a bad connection,double check all of them!Good luck!!
Originally Posted by spn2448,Apr 2 2005, 02:44 PM
the code is P1367 (manufacurer control ignition system or misfire)
Could this have to do with the vortech timing control box?
I'll bet you have a bad connection or you cut the wrong wire.
Jaykkub
Oct 5, 2004 12:03 AM
Daremo
Oct 1, 2002 01:08 PM
