Please Help!
Old Apr 2, 2005 | 10:06 AM
spn2448's Avatar
Default Please Help!
I just install finished installing my vortech and the car run fine except the check engine light came on and I can't go above 3500 rpms.
Old Apr 2, 2005 | 10:13 AM
Sideways's Avatar
Double check all your electrical and vacuum connections. That little vacuum canister in the front causes lots of problems. Pull the ECU codes.
Old Apr 2, 2005 | 12:44 PM
spn2448's Avatar
the code is P1367 (manufacurer control ignition system or misfire)
Could this have to do with the vortech timing control box?
Old Apr 2, 2005 | 01:38 PM
joes sled 2000's Avatar
Did you solder you're connections or did you use the lame ass butt connectors vortech gives you?If you did not solder the connections then that is most likely you're problem.If you did solder the connections then you have a bad connection,double check all of them!Good luck!!
Old Apr 2, 2005 | 02:09 PM
xviper's Avatar
I have P1367 as "Top Dead Center (TDC) 2 Sensor No Signal".
I'll bet you have a bad connection or you cut the wrong wire.
Old Apr 2, 2005 | 03:00 PM
spn2448's Avatar
yup it was a bad connection all fix now thanks
Legendsniper87
Nov 14, 2010 11:48 PM
had2haveit
Sep 14, 2005 06:55 PM
GoFaassttt
May 24, 2005 03:45 PM
Jaykkub
Oct 5, 2004 12:03 AM
Daremo
Oct 1, 2002 01:08 PM
