is this possible?
I know this may not be recommended but I'm installing an inline pro stage 1 kit and I still need to have my down pipe taken care by the muffler shop that is only a few miles away. Can I drive the car with stock ECU, stock injectors, and stock MAP sensor with the turbo kit installed to the shop as long as I stay out of boost or keep the revs low?
If not, then I will go ahead and install everything including the EMS, ID injectors, and MAP sensor; tow it to the muffler shop to get the down pipe done, and then bring it home and tow it to the tuner another day.
dont have to drive slow if you take off the charge pipe to the intake mani and put back on your stock filter . The turbo can run all it wants but none of the air will go into your intake mani. Now you can drive your car as it will be stock.
