is this possible?
Old Sep 11, 2011 | 05:38 PM
gnehc1's Avatar
Default is this possible?
I know this may not be recommended but I'm installing an inline pro stage 1 kit and I still need to have my down pipe taken care by the muffler shop that is only a few miles away. Can I drive the car with stock ECU, stock injectors, and stock MAP sensor with the turbo kit installed to the shop as long as I stay out of boost or keep the revs low?
If not, then I will go ahead and install everything including the EMS, ID injectors, and MAP sensor; tow it to the muffler shop to get the down pipe done, and then bring it home and tow it to the tuner another day.
Old Sep 11, 2011 | 06:25 PM
miguel329's Avatar
i did that with my gsr hatch didnt hurt anything. i had stock ecu and injectors and map sensor, had turbo all hooked just didnt get in boost
Old Sep 11, 2011 | 06:32 PM
gnehc1's Avatar
Thanks. That will save me a tow to the muffler shop.
Old Sep 11, 2011 | 06:49 PM
ftpsk8's Avatar
Yeah you'll be fine I had to do the same thing just drive slow
Old Sep 11, 2011 | 07:35 PM
gnehc1's Avatar
thanks. I also PM'd you the other night...did you get it?
Old Sep 11, 2011 | 10:21 PM
TonysMI4's Avatar
dont have to drive slow if you take off the charge pipe to the intake mani and put back on your stock filter . The turbo can run all it wants but none of the air will go into your intake mani. Now you can drive your car as it will be stock.
gnehc1
Sep 11, 2011 08:27 PM
Ek_Jak
May 13, 2010 12:18 PM
killabee
Mar 22, 2009 02:08 PM
Spec_Ops2087
Mar 21, 2008 06:58 AM
