Post your Catch Can Setups
Old Jun 18, 2012 | 02:35 PM
  #131
speedjunky01's Avatar
here is the setup on my vortech kit
drilled the intake and bought a grommet and 90* ford PCV elbow that is straight through, ran one end to the can, then the other to the stock VC vent. the can is also baffled on the interior. I used some steel tube with holes in it to force the vented oil mist to the middle/bottom of the can (which is stuffed with steel wool for the oil to stick to) I also added a 1 way valve after the stock vent so if the intake manifold is drawing more vac then the s/c intake it will still be vented
keeping it vented on and off boost for the about $45 that I have into it, I think its a GREAT setup
Old Jun 19, 2012 | 08:34 PM
  #132
S2KiChad's Avatar
Originally Posted by herecomesboost
Originally Posted by S2KiChad' timestamp='1336553955' post='21681903
i wanted to know what do you with all the vacuum hose for the intake since they are hardline and what are they all connected to?
Are you talking about the hardline from the breather to the intake (that is welded to another coolant hardline)? If so, I just remove that entire set of hoses and run a new coolant line.
yes those line do you have a pic on how to route it?
Old Jun 20, 2012 | 05:23 AM
  #133
herecomesboost's Avatar
I'll likely run a filter on the breather port (my car is still in pieces):
Old Jun 20, 2012 | 08:09 PM
  #134
benlee02's Avatar
Just got done installing my setup!
Old Jun 21, 2012 | 06:11 AM
  #135
Clean
Old Jun 21, 2012 | 05:12 PM
  #136
Japmuscle's Avatar
ok ok so Im doing a SC build and Im confused: why are some people only venting the catch can while others are plumbing it to the intake (before FI boost pressure, so there is only ever vaccume)???
If I understand correctly, you need to have a vent to atmosphere for WOT conditions AND a catch can plumbed to a vaccume source (like the intake) for suction under idle or light load conditions as the pressure in the crank case/valvle cover isnt enough to force out the blow-by fumes.... am I correct?
Plz advise on a cheap easy set up!
Thanks guys!
Old Jun 21, 2012 | 05:23 PM
  #137
An ideal catch can/vent system will not recirculate back into the intake
Old Jun 22, 2012 | 09:03 AM
  #138
Japmuscle's Avatar
Why is that? does the system not need vaccume from the intake to remove harmful gasses from the crankcase? I was under the assumption that the catch tank was to remove the oil vapors from the air that went into the intake???
thx for the advise
Old Jun 22, 2012 | 09:09 AM
  #139
The system doesn't need vacuum. Recirculation (like the factory setup) is done for emissions purposes. Pressurized gases from the crankcase will evacuate without issue. It's really up to you, honestly. If you would prefer a closed system, go for it. The differences between an open/recirculated system will be negligible/marginal in most cases anyway (with regard to pressure evacuation).
Old Jun 25, 2012 | 03:43 AM
  #140
Japmuscle's Avatar
ohhhh ok ok I gotcha! Vented it is then!
Thx bud!!
