pretty sure my diff exploded
Old Jul 3, 2010 | 03:47 PM
  #31
DFWs2k's Avatar
any tips for getting the top bolts on the axles? i only had a short 14mm wrench so wasn't able to get very far on the very top ones, and i rounded off the damn bolt that holds the charcoal box thing in lol
Old Jul 3, 2010 | 03:48 PM
  #32
DFWs2k's Avatar
Originally Posted by JoeyBalls,Jul 3 2010, 10:10 AM
damn............. I was barely able to keep up with a C6 Z06 (slighly started to catch up) at 550RWHP, either your car is a beast of that F---- was modded
i probably just got the jump
Old Jul 3, 2010 | 04:05 PM
  #33
fatjoe10's Avatar
Did you check the driveshaft? seen a few snapped with the same symptoms.
Old Jul 3, 2010 | 04:11 PM
  #34
DFWs2k's Avatar
everything looks normal under the car
Old Jul 3, 2010 | 05:52 PM
  #35
AusS2000's Avatar
I had a similar incident off a stop light.
I got a buddy to look under the rear while I let the clutch out in first. He saw the right CV cup spin. Was my axle.
Old Jul 3, 2010 | 06:32 PM
  #36
dammitjim's Avatar
Why worry about axles when the diff is so cheap and easy to replace?
Old Jul 3, 2010 | 07:10 PM
  #37
bluemetals2k's Avatar
cause it might be the axles??? And save him time money etc from buying a new diff!!!
Old Jul 3, 2010 | 07:22 PM
  #38
chairmnofthboard's Avatar
The top ones on the axles? Just rotate them to the bottom. Is that what you are talking about?
Old Jul 3, 2010 | 08:27 PM
  #39
fatjoe10's Avatar
Did you actually try to spin the driveshaft with your hands with the car in neutral or just look at it?
Old Jul 3, 2010 | 09:16 PM
  #40
D1sclaimer's Avatar
You do know that if the axle is broke and the differential is fine, then it'd be pointless to put in a new differential with the same broken axle? Right?
See if the cheaper part is the problem first, then move to other possibilities if it was not the problem.
