PTUNING S2000 Oil Distribution Block & Vacuum Block
Old Jul 9, 2012 | 07:29 AM
  #141
doug@PTUNING's Avatar
Originally Posted by Sarek
Thanks! Here's another view.
The fitment is great except that it hit the head a tiiiiiny bit (not even .010"). I just shaved some material off the head with a dremel. I'm sure it was the lack of consistency with the OEM head castings ...Just fyi.
No gripes at all. The Ptuning workmanship is top notch!
Sent from my HTC Glacier using Tapatalk 2
Look awesome!
Old Jul 9, 2012 | 08:31 AM
  #142
Sarek's Avatar
Thanks! Just need to clean my valve cover
Old Jul 10, 2012 | 09:04 AM
  #143
MrC@PTUNING's Avatar
Is anyone running a temp sensor for the oil via ODB?
If this is not a "good" source, Where is a good spot for an oil temp sensor that doesn't require tapping and welding?
The aftermarket oil temp sensor should be mounted where you mounted the factory oil pressure sensor on your ODB block--due to the length of the temp sensor. We made the top corner port specifically to accommodate the length of an aftermarket temp sensor. The factory oil pressure sensor can be mounted on either one of the two ports you have plugged up on the front face of your ODB block.
MrC
Old Jul 10, 2012 | 09:17 AM
  #144
Sarek's Avatar
MrC
Perfect! Thanks, I'm shopping for the sensor now!
Old Jul 10, 2012 | 09:22 AM
  #145
liquidgsr's Avatar
I still need to come by this weekend and buy this. I forgot to come last Friday, but I will try and remember to come this Saturday morning.
Old Jul 10, 2012 | 09:24 AM
  #146
TerminatioN's Avatar
So does that mean if you run an oil temp sensor then you can't use the OEM oil pressure sensor? Or is there another place to put it?
I was hoping to have aftermarket oil temp and pressure sensors, as well as the factory pressure sensor (and feed line for the turbo). Is this possible or I will have to pick 2 out of 3 of the sensors? Kind of hard to tell from some of the pics how many ports there are and what they can be used for...
Old Jul 10, 2012 | 09:43 AM
  #147
robotvoice's Avatar
You can put a temp sensor in the top port of the block and the OEM and aftermarket pressure sensors on the front of the block. There's definitely enough spots.
Old Jul 10, 2012 | 09:45 AM
  #148
Sarek's Avatar
MrC
You'll have 8 TOTAL ports. 3 of which you will need (oil feed, turbo feed, and if you want the dash light functional- OEM pressure sensor) you'll have 5 more after that at your disposal
In the picture, the "yellow" circles in front are plugs for the unused ports. There's 2 more, one on the bottom to the right of the pressure sensor and 1 more on the right side which you can't see.
Old Jul 10, 2012 | 10:34 AM
  #149
Ahhhh ok. Thanks for the clarification Sarek/robotvoice. I knew there must have been more ports. I was just confused.
Definitely an awesome product. Can't wait until I can afford one.
Old Jul 14, 2012 | 04:07 PM
  #150
liquidgsr's Avatar
I bought the distribution block but it's missing the bolts to
Mount it to the block.
