PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Originally Posted by HMFIC' timestamp='1313065515' post='20867901
[quote name='dales2000' timestamp='1313029446' post='20867002']
[quote name='HMFIC' timestamp='1313026075' post='20866859']
[quote name='sata3000' timestamp='1313025599' post='20866831']
[quote name='dales2000' timestamp='1313013882' post='20866255']
Another fuse blew. I'm trying a 20amp now
[/quote]
Yup I was told not to use a 20amp fuse. I blew three 10amps in a row. I think there is an issue with my pump I gotta call toan.
[/quote]
Wait, you're the one that has the pump that's making extra noises correct? My fuse blew as well and i just upgraded to the 20 amp. The pump is just putting an extra load and needs the bigger amp to compensate.
[/quote]
Nah that was Blucky87. I was told not to use a 20 amp because it can fry the wires. I wonder if it has something to do with using the ac. A friend of my said I should try wiring it directly to the battery but if the pump is bad then I won't when its working and I will risk destroying my turbo or worst. I am just glad its blowing on start up and not when I am driving.
[/quote]
Wiring directly to the batter and putting in a relay to click the external pump on is ok as well. Those pumps come with a nice warranty so if you're willing to drop by ptuning or call them to rectify the issue, you can swap out the pump.
When i got my car back from being finished at Ptuning in January, I drove directly to my paint shop for some work to be done. I went there a couple days later to do something and I went to move the car in the shop. I then noticed the oil light has been on. Since it was pretty chilly, i put on the heat and noticed no hot air. I didn't think about anything else but I called Toan. This was like after 20 min of letting the car warm up thinking that's why the heat wasn't coming on...
He told me to pull the fuse to check. Sure enough it was smoked. He said replace it and I would be good to go. I've done it then, and ever since then, i've never had an issue.
Originally Posted by dales2000' timestamp='1313069634' post='20868040
when did you upgrade your fuse to the 20amp? For how long?
From: Performance Tuning (PTUNING) 9432 Center Point Lane Manassas, VA 20110
Allan seems to have covered it pretty well so if you have any other concerns or questions, please don't hesitate to give us a call here at the shop.
-Brian
-Brian
Originally Posted by HMFIC' timestamp='1313070317' post='20868070
[quote name='dales2000' timestamp='1313069634' post='20868040']
[/quote]
Ok I just re read my post a couple pages back. I just got off the phone with toan...It's a 10 amp. not a 20. Have you tried a 10 amp? Everyone SO FAR that upgraded to the 10 amp has not had any issues anymore.
Toan said to call if you have issues after the 10 amp, because he has a solution.
Yea it's odd. But so far, anyone that upgraded to a 10 amp has been good to go..
Gotsta come by! need to buy some red bull for yall!
Im just posting up to help others in case they have my problem later on. I already put 3000miles on this kit in less than three months. I was fine on the 7.5 amp fuse for like 2800 miles it blew then I switched to the 10amp for about 200miles then that blew.
