PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old Feb 1, 2012 | 01:07 PM
  #2081
TerminatioN's Avatar
One more odd question for you guys... not sure if you'll be able to answer, but worth a shot...
Is there clearance at the bottom for the compressor housing to be spun 180 degrees, so that the outlet is facing downwards?
My reason for doing this would be so I could change the intercooler piping to run under the cross member instead of over. Just leaves a lot more room in the engine bay for other various things.
Old Feb 1, 2012 | 01:19 PM
  #2082
MrC@PTUNING's Avatar
Our kit already comes with a 4" intake so there's no need to rotate the compressor outlet
MrC
Old Feb 1, 2012 | 01:28 PM
  #2083
MrC
Sorry, I edited my post after realizing that. That space is also already allocated for a catch can and some other things on my car anyways though...
So any idea of the compressor housing has clearance at the bottom to be rotated 180 degrees?
Old Feb 1, 2012 | 01:48 PM
  #2084
We'll have to check to let you know. Do you have link to your engine bay and catch can
Old Feb 1, 2012 | 02:57 PM
  #2085
Thanks, that would be great. No, no current pics, sorry. I guess I can move stuff around if need be, that just seems to be the best place for it, and I just worked out a custom mount for it there, so I would really prefer not to if at all possible.
Old Feb 2, 2012 | 12:32 PM
  #2086
andrew@ptuning's Avatar
PTUNING February Love specials:
1.Upgrade to the GTX-3076R for Free ($300 value)
2.Or take $300 dollars off any PTUNING S2k turbo kit.
3.Included with the purchase of a PTUNING turbo kit. A Free Vacuum Block Manifold ($64.95 value)
Call today!!!!!
Drew
https://www.s2ki.com/...0#entry21367040
Old Feb 2, 2012 | 04:04 PM
  #2087
JspecVtec's Avatar
is an electronic boost controller or boost solenoid much better than a manual one? would it smooth out the boost build up on partial throttle? i feel like under partial throttle there are notches when climbing boost and speed
Old Feb 2, 2012 | 04:23 PM
  #2088
An electronic boost control via an EBC or ECU is the ideal setup but it sounds to me like you might have a tuning issue and not necessarily a boost control issue. With a good tune your partial throttle and full throttle should be smooth and seemless. You might just need to have your tuner to touch up on your partial throttle map.
MrC
Old Feb 4, 2012 | 04:26 PM
  #2089
2forty's Avatar
Just curious or if i missed them, has there been any 91 octane dyno pulls? or on an ap1? 14psi on 93 octane seems to be the limit on stock motors, how much boost would 91 octane limit us people with piss cali gas?
Old Feb 4, 2012 | 07:49 PM
  #2090
SpoonTunage's Avatar
Why is this kit so much more money compared to mase's kit which yields same power pretty much?
