PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old Jan 29, 2012 | 05:00 PM
  #2071
miguel329's Avatar
i did 13.17 at track today on some bs worn out nexen 3000 tires,in 1/4 mile. on evans etune 12 psi, no launching just pulling out hole nice. hoping some slicks, a more agressive tune will yield me better numbers. i went to a track in fayettville nc, i realized alot people havent heard of you guys had lots of questions bout the kit.. gtx30r turbo. 2006 s2000 2.2 engine. was first time ever i ran at a track
reaction 1.4085
60ft 2.39
330ft 5.9668
1/4 e/t 13.17
1/4mph 113.39
Old Jan 30, 2012 | 01:32 AM
  #2072
2forty's Avatar
What did you trap??
  #2073
2forty's Avatar
What did you trap?? What turbo??
Old Jan 30, 2012 | 10:32 AM
  #2074
jco2301's Avatar
If when you guys install the kit and hear compressor surge the problem is with the BOV. It comes with 2 springs pre-installed (1 with blue painting and one with pink painting). Open up the BOV using the supplied wrench and remove the blue spring leaving only the pink. The car will sound much better and the compressor surge will be eliminated.
Old Jan 30, 2012 | 12:41 PM
  #2075
miguel329's Avatar
mine didnt have any surge never even opened the bov.
Old Jan 30, 2012 | 01:17 PM
  #2076
robotvoice's Avatar
That doesn't sound right. Looking at the turbosmart specs, it seems like the springs that came with the port are correct for the vacuum level I am seeing on my kit.
Old Jan 30, 2012 | 02:04 PM
  #2077
JspecVtec's Avatar
reaction 1.4085
60ft 2.39
330ft 5.9668
1/4 e/t 13.17
1/4mph 113.39
lol thats a really slow reaction time
Old Jan 30, 2012 | 02:40 PM
  #2078
miguel329's Avatar
Originally Posted by JspecVtec
reaction 1.4085
60ft 2.39
330ft 5.9668
1/4 e/t 13.17
1/4mph 113.39
yes i know was first time out there, sure with some pratice it be better.
Old Jan 31, 2012 | 07:22 AM
  #2079
andrew@ptuning's Avatar
I have posted up our February special. Check out the link below for this months S2ki promotion!!!
Thanks Drew.
https://www.s2ki.com/s2000/topic/925...#entry21367040
Old Jan 31, 2012 | 08:43 AM
  #2080
MrC@PTUNING's Avatar
Agreed
You should not remove any of the springs in the BOV. We specifically had Turbosmart spec our BOV with the dual springs (blue and pink spring) since the s2k motor draws around 20-22in/hg vacuum at idle. If you are truely experiencing compressor surge (air backing up to the compressor wheel causing it to want to stall) due to the BOV not opening when TB is closed, then there is a chance that your vacuum line to the BOV is not connected to the proper vacuum source. We have had a few customers accidentally connect the vacuum line from the BOV to the WMI (water meth injection nozzle) port on the billet IAT sensor/vac block plate on the upper intercooler piping (near the throttle body). Please verify that your vacuum line is properly corrected to the correct vacuum source. Feel free to send us a picture of your BOV vaccum line connection for us to help you confirm the installation.
If you run the BOV with just the smaller inner spring (pink), you may experience the BOV fluttering when you're on and off the throttle.
MrC
