PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Originally Posted by p0staboy' timestamp='1368400346' post='22537707
So I was talking to my tuner and he said this
The popping is an anti-lag system, and it's not within the tune. There is a PWM valve in the exhaust stream that pulls in air based on RPM + timing retard to make it function.
For your turbo size, it is not advised to install such a system because it will blow apart the turbo . The turbo needs to be well sized for this application, and you'd only want it when you want to pre-spool the turbo under decel conditions.
I have a GTX30 ,I've seen cars with gt30s shoot flames weird how mine isn't big enough
I'm in the process of installing this kit. Do all of you guys run the 2.5 inch reducer in the exhaust? I'm going to get tuned on 91 octane so boost will only be about 11-13 psi. Do I only have to run the exhaust reducer only if my wastegate reciceulates back into the downpipe?
how much boost do you run though and with what fuel? The p tunning instruction clearly state that when running pump gas at less than 15psi of boost that the exhaust 2.5 inch restrictor much be used to avoide boost creep. The instructions also say that when running race gas/e85 and running high boost ( more than 16psi and more than 500whp) The restrictor can be removed and there will be no boost creep when boost is set that high.
I'm going to be running straight 91 octate at 11-13 psi of boost. I would like to avoid running the exhaust restrictor if possible. I have a full straight through 3 inch exhaust system with no cat.
Sent from my SPH-L710 using Tapatalk 2
For 11-13 psi you'll best run the 2.5inch restrictor. You may still creep to 13-14psi.
My thinking is, I'm running a 3" exhaust, why put a 2.5" in there. My as well run a 2.5" exhaust?
I'm at 17-18psi on 91oct without a restrictor with lots of timing retard, daily hard driven. No worries about boost creep there. Plus what is the boost efficiency of a GTX3076R?
I'm hoping to blow my motor so I could build it.
