PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Old Apr 21, 2013 | 12:14 PM
  #2661
sata3000's Avatar
Alright, Do you think I'll have to remove anything to access them? Like the dump tube or wastegate?
Old Apr 21, 2013 | 06:29 PM
  #2662
Suzuka_Joe's Avatar
i'd imagine you'll have to remove some stuff to get to all the bolts
Old Apr 22, 2013 | 02:10 AM
  #2663
sata3000's Avatar
Ya i looked.looks like damn near everything
Sent from my Galaxy S II using Tapatalk
Old Apr 22, 2013 | 04:50 PM
  #2664
miguel329's Avatar
Yea you do.. I'm putting in the locking tabs for the gtx turbo housing bolts that I bought from ptuning and no way to loosen them without pulling it out, it sucks. Also pulling the dp sometimes need a new vband flange mine was seized & bolt snapped taking it off.
Sent from my SPH-L710 using Tapatalk 2
Old Apr 23, 2013 | 01:44 AM
  #2665
sata3000's Avatar
Thanks Miguel. Guess I'll go ahead and buy a new vband clamp and locking tabs. Figures right when the weather breaks I've got to pull her apart.
Old Apr 24, 2013 | 06:29 AM
  #2666
Forcedbird's Avatar
I have the new pipe installed now. After a test drive I noticed heavy scratches on the new pipe that weren't there before. So my guess is that the charge pipe is rubbing the manifold under load.
Yes, you should remedy this situation first, but I also suggest that you run an exhaust manifold blanket like I did.
[attachment=37978:IMG_6967.JPG]
[attachment=37979:IMG_6974.JPG]
Attached Thumbnails PTUNING S2000 Turbo System (Pics, Dyno, Pricing)-img_6967.jpg   PTUNING S2000 Turbo System (Pics, Dyno, Pricing)-img_6974.jpg
Old Apr 24, 2013 | 07:01 AM
  #2667
Suzuka_Joe's Avatar
that looks like a good idea. I have a top mount pfab setup and with the turbo blanket i can touch it and not burn my hand after a drive
Old Apr 24, 2013 | 08:35 AM
  #2668
herecomesboost's Avatar
***images removed***
Where did you buy the manifold blanket? Looks great!
Old Apr 25, 2013 | 11:22 AM
  #2669
miguel329's Avatar
Originally Posted by MrC@PTUNING
Originally Posted by sata3000' timestamp='1366458728' post='22486988
I think my new charge pipe is too long. About 2.5-3 inches different. Do you all think i can still use it?
You need to compare the length by stacking one pipe over the other so you can see the diff in length but they should be the same so you should be fine.
Pmed you mrc
Old Apr 26, 2013 | 10:15 PM
  #2670
riceball777's Avatar
because this use uses an after market motor mount does the car vibrate a lot more. I ask because i use instaled hasport 62 mount mounts on my s2000 and the car vibrates like crazy and is not livable so i had to put the stock mounts back in
