PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Free bump!
I read every ptuning post in the thread over the past two days. I skimmed through the rest, just to much to read! Such a quality kit, even with the few issues. Speaking of which, have the issues with the intake arm weld breaking and the motor mount weld breaking been solved? Alot of people seem to concentrate on other aspects of the kit, but as of right now im more concerneted about the two items i listed.
Im very excited to see the results of a 3576 on a f22 with pump gas and possibly a 3582 on a f22 with pump gas.
Id really like to do a gtx3576 build and compare the ptuning vs the sos kit i had!
Sent from my Samsung Galaxy S4
We added a triagulated bracing to our intake tube over a year ago.
In terms of the motor mount, we have never had any reported issues with the motor mount bracket. The bracket is very beefy and actually uses laser-cut notches to allow the arms to attach to the bracket plate before welding. If there were any issues though, we could very easily over-engineer the bracket to make it even stronger.
From our brief testing on a built Genesis 2.0T (comparing GTX3576R to GT3076R), we're pretty confident that the GTX3576R will perform well on the F22C engine. I'll predict 450+whp on our Dyno Dynamics dyno and 480-490+whp on a Dynojet with 93 pump gas, an efficient 3" exhaust system, and about 14-15 psi boost.
- Toan
The reason we developed our turbo system with an aftermarket 16" Spal fan is because we wanted to stick with 2.5" hotside piping and it is impossible to fit the pipe between the AC hard lines and passenger-side fan shroud without having them squished up against each other. Throw a thicker Koyo radiator into the mix and this becomes virtually impossible. We could have gone through the fender hole, but we didn't like the idea of removing the fender/headlight support bracket either.
We're working on a few optional cooling upgrades and will have more info on it in the next month or so.
- Toan
Ptunning, I'm still waiting of the answer to this question. Is is possile to use other V-band turbo's with your kit? Like the soon to be released EFR 7163?
Also would you guys consider making a V-mount intercooler/rad kit? It has pretty much been proven to be the most efficient setup for keeping everything cool. I would love to run your Turbo kit with that setup.
SOS has one coming out for there Turbo kit and because of that they somwhat have my interest. Please level the playing field and take my money.
We could definitely develop a totally badass V-mount intercooler/radiator/relocated condensor set-up.
It would require a custom radiator and AC lines though. The question for us is would we be able to sell enough of them to justify the development time/costs.Right now, with a Koyo radiator and our oil cooler system in place, we have no problems with overheating at the track (roadcourse). A V-mount set-up for us would be more about looks rather than function. Sure it would shorten the intercooler path, but the boost response we have now is really nothing that needs to be addressed. I guess we should look into starting a poll to gauge interest.
- Toan
- Toan
I've always loved the shorter intercooler path of the V-mounts along with the better cooling benefits.
Please do start a poll to gauge interest. I'm sure there are more then a few who would be interested.
- Toan
- Toan
Regarding your kit on the track. Have you guys done extensive testing on a road course with your kit? It seems like many FI s2k's run fine with cooler ambient temps, but when temps get up into the 90's that's where problems pop up.
- Toan
- Toan
What do consider extensive testing? There was a guy"Metros" who tracked his car quite a bit and had no overheating issues. He also had the optional oil cooler as well. I think if you want to track the car shielding like I have done would help tremendously. Keeping the boost lowered would also help. 8-10psi for a road course. Maybe up boost to 14 in 4th or higher gears. This kit and the SOS kit are probably the best for a road course.
Toan,
Thank you for the reply! You posted a picture of exactly what I needed to see! Below is the post I was referring to. It seems the motor mount failed for Batbite, or perhaps the photo is showing something else...? My last question is, how does the "time attack red" powder coating match the factory color/wrinkle of the factory S2000 valve cover?
As far as the SOS vs Ptuning, I already know it will pull the rug under SOS's feet as far as hp/trq, as well as response and EVERYTHING else, I just didnt want to put it that way initially. I want people to see the main difference, and doing that on the same dyno will prove it even for the non believers.
Dustin
Dustin
When I was under the car looking to see what was what.... I noticed that the PTuning passenger side motor mount had also craked all the way around
Andrew (or one of the other Cust Svc Guys) I'll give you a call in the am. I'm going to have a local shop Tig-Weld the DT, but I could use a bit of help with a rep Motor Mount.
Thx
Thx
Huh? It sounds like you got the wrong kit (SOS kit) initially. If they overpromised you in the power department that's one thing, but both kits have their advantages. There are always advantages and disadvantages to every kit. I don't like the idea of an oil scavenging pump and different motor mount, but that doesn't mean it isn't a good kit for someone else. Power isn't everything to some people.
