PTUNING S2000 turbo system re-release
Old Dec 5, 2017 | 06:35 AM
  #371
Mijae007's Avatar
Originally Posted by sirbikealot7
@Mijae007 yes, -12 from the catch can to the exhaust port, it will have a check valve in that line with flow toward the exhaust and a check valve under the filter, so the crankcase can vent out of the filter at idle, and once the venturi is strong enough to pull a vacuum the filter check valve closes, and the vent line opens drawing all the excess crankcase pressure into the exhaust, the catch can is baffled so it will condense almost all of the oil and water vapor and then the very small remainder will go into the exhaust, but the resonator and muffler are both straight through, it won't cause any fouling problems with the exhaust.
This is very interesting. Ive debated so many different catch can setups when deciding mine but never came across one like yours.
Sorry but my inquisitive nature has me asking more questions. Do the new port sites on the opposite side of the vc have the same effect as the factory locations (pcv [center] and crankcase vent [front])?
and because of the way (angle) the scavenge pipe is welded to the exhaust, does it actually create positive vacuum under idle and throttle out the exhaust? Im concerned exhaust air will still get pushed out that way up into your catch can instead of drawing air out...
if this works the way it was intended, i may just have to reconsider my setup too!
Old Dec 6, 2017 | 02:26 PM
  #372
sirbikealot7's Avatar
No problem, I've got some final finishing up to do with it and need to hook up a manometer to adjust and maximize the venturi in the exhaust. I'll post up with my results when it's all finished.
Old Dec 7, 2017 | 10:48 AM
  #373
RollCage's Avatar
I say this with much regret, but if anyone is looking for a PTuning kit, Option 2 (everything but the intercooler) with the GTX3576R Gen 2, shoot me a PM. It's all new and in the original packaging from PTuning.
Medical stuff sucks. A lot.
Old Dec 7, 2017 | 05:35 PM
  #374
visionxboy's Avatar
Just curious what brand and what type of gauges are you guys running? Specifically, 06+ with flashpro, do I need AEM EMS to run the AEM gauges? I really wanna use the AEM AF/Boost 2 in 1 along with an Oil Temp gauge.
Old Dec 8, 2017 | 04:29 AM
  #375
rmerchant3's Avatar
The CAN gauge/Gauges are the way to go. Ask Dustin about getting it to work on flashpro, He may be able to help. With the AEM computers, it's really simple.
Old Dec 12, 2017 | 06:45 AM
  #376
King Tut's Avatar
I run the AEM Failsafe which is the two in one boost and wideband. It comes with the wideband and then you just have to run a very small vacuum line up to the gauge.
Old Dec 12, 2017 | 08:29 AM
  #377
JUSTINTHECOASTIE's Avatar
Same here, also it's programmable for its own way to alert you
Old Dec 12, 2017 | 09:24 AM
  #378
CoolGuy094's Avatar
Its the best gauge of all time.
OF ALL TIME.
Old Dec 12, 2017 | 10:09 AM
  #379
OF ALL TIME.
It's the yeezy of gauges
Old Dec 12, 2017 | 10:20 AM
  #380
s2000ellier's Avatar
has anyone wired in the failsafe to an AEM series2, which pin did you use, what settings did you configure on the series2 to respond?
