Pulley Replacement and Upgrade for higher boost
Old Mar 9, 2005 | 05:36 PM
johninator's Avatar
Default Pulley Replacement and Upgrade for higher boost
Any recommendations to where to buy pulleys for the Vortech kit?
Is there a company that has the pulley with belt guides to hold the belt in place such as the pulley from the crankshaft?
What would be the recommended boost and injector size for each boost level on stock internals?
Old Mar 9, 2005 | 06:40 PM
Slows2k's Avatar
Moving to FI.
Removing the SC from the car and using an impact wrench to loosen the pulley's bolt is the common practice.
Old Mar 10, 2005 | 05:51 AM
Sideways's Avatar
ASP Racing makes custom pulleys one at a time to your specifications and they have a lip like you want. Candace is the lady taking the orders and she is very knowledgeable. Reasonably priced and well engineered products.
How are you planning on getting larger injectors to work, AEM or Fcon? If not, you need to do some sole searching and decide if you want to spend the big bucks to do it correctly or big bucks to fix or replace your blown engine.
Old Mar 10, 2005 | 06:16 AM
johninator's Avatar
Phil,
With 9psi and below, I am thinking of using 440 or 550 injectors & AEM FPR with the stock vortech setup. Im not sure if this would work properly especially at low RPM drivability. Any recommendations?
I am planning to use the AEM ECU and FPR to control the fuel with anything over 9psi of boost. Is there any deals on the ECU extension harness?
Slow,
Can we just leave the supercharger propped off while leaving the oil lines and such connected to impact the pulley off?
Old Mar 10, 2005 | 08:36 AM
Sideways's Avatar
Originally Posted by johninator,Mar 10 2005, 07:16 AM
Phil,
Slow,
With the AEM EMS you will be fine. I suggest you go with the 750 injectors since they will support anything you want with that setup at normal fuel pressures. They idle great, smoother than the factory setup.
Old Mar 10, 2005 | 01:06 PM
Jason00S2000's Avatar
I still have 2 9 psi pulleys and 1 11 psi pulley for sale.
I went with the AEM and 4 785cc injectors.
Old Mar 11, 2005 | 11:10 PM
SCvortech's Avatar
how much do you want for the pulleys please PM me incase i dont revisit this post
Old Mar 12, 2005 | 06:15 AM
Slows2k's Avatar
Originally Posted by johninator,Mar 10 2005, 09:16 AM
Slow,
It would be easier for me to take the SC and brackets off the engine as an sssembly. Depending on pulley size, you'll need a shorter belt, which requires the SC to come off anyway.
Old Mar 12, 2005 | 06:16 AM
Slows2k's Avatar
Jason and SCvortech, If you want to buy or sell pullies, keep it in the FS or WTB forums.
s2kseven
Jun 13, 2019 11:17 AM
liquid_helix136
Feb 13, 2015 08:25 AM
sirguy01
Oct 8, 2008 04:47 PM
dustinmallen
Feb 4, 2007 07:26 PM
dave22
Jan 24, 2005 06:53 AM
