Pulley Upgrade question
Old Jul 20, 2005 | 10:05 AM
SIIK2NR's Avatar
Thumbs up Pulley Upgrade question
I was discussing upgrades the other day and it dawned on me that for an 03 SC kit that runs a 5.5lbs stock, then upgrading to a 7lb pulley would be worth it.
My question is: The CT SC w/AC for the 04 kit comes with a smaller pulley as is and is somewhere around 6lbs stock with a lower redline. Is upgrading to a 7lb pulley which is really for an 03 kit worth it?
What I'm getting at is....is there an 8lb pulley that I could safely run on stock injectors without Engine management? In theory I would only be achieving 7lbs at peak because of my AC w/front mount set up.
thoughts?
Old Jul 20, 2005 | 10:25 AM
Asura's Avatar
How boost loss is there with the front mount?
With the reduced redline you would also get less max psi. There is an equation here that should get you pretty close.
Old Jul 20, 2005 | 10:44 AM
Silver S2k4's Avatar
With the tech 2 3.5" pulley I had 6.6psi. This was the pulley that was supposed to produce 9lbs on the 03 kit. Each .25" is a pound.
But you will need injectors if you do any kind of boost upgrade on the 04. Like the ones I have for sale right now
https://www.s2ki.com/forums/index.ph...f=107&t=305571
I went through the same thing and asked a lot of questions that no one could answer. Now I can answer them for everyone else.
Old Jul 20, 2005 | 11:58 AM
SIIK2NR's Avatar
Thanks Silver... That's what I was thinking.... Upgrades to the 04 kit require immediate upgrades to the injectors...
What to do...what to do.....
Old Jul 21, 2005 | 06:43 PM
R.P.M's Avatar
Damn Tim, you just installed you kit and you are already greedy for more boost?
Old Jul 22, 2005 | 08:06 AM
coquinn's Avatar
So ...you can't run the Tech2 7PSI pulley on a MY2004 without upgrading the injectors? What else is needed to run the Tech2 7PSI pulley on a MY2004?
Old Jul 22, 2005 | 08:16 AM
slamar1's Avatar
PM sent
Totalpkg
Jul 9, 2015 05:11 AM
vadik_s2k
Aug 11, 2011 11:42 AM
TheBigShow
Sep 2, 2009 08:11 AM
jdmdohcpower
May 18, 2009 12:28 PM
