question regarding oil lines
Old Jan 28, 2018 | 07:09 AM
s2kneub's Avatar
Default question regarding oil lines
hey,
can anyone show me the optimal location for the oil return port from the turbo to the block? also, where is the best location to run the oil feed line from? any help would be greatly appreciated..thank you.
Old Jan 28, 2018 | 11:47 AM
5thgen's Avatar
Originally Posted by s2kneub
hey,
A lot of people use the timing cover for a return point. A fitting on the passenger side of the oil pan will usually be below the oil level.
Most use the feed from the oem oil pressure light switch. It is easy to use and is filtered oil. Just remember its a 1/8 british thread.
Old Jan 28, 2018 | 02:19 PM
s2kneub's Avatar
is it safe to tap the girdle for the return? also, would using the oil pressure switch feed force a delete of the switch?
Old Jan 28, 2018 | 05:54 PM
staylor725's Avatar
Girdle or timing cover is best for the return, use this fitting in the link for the oil feed. Here’s a installed picture of it also.
Stock Oil Feed Adapter
Old Jan 29, 2018 | 05:56 AM
s2kneub's Avatar
awesome...thank you so much.
Old Jan 29, 2018 | 04:34 PM
jordannn93's Avatar
Top driver side of the oil pan for oil return. Oil pressure sensor area for feed.
DontWreckIt
Jan 9, 2013 05:36 PM
S_KAR_G0666
Sep 14, 2011 02:17 PM
Lord-Jaffa
Nov 26, 2009 06:08 AM
John MI blk/blk '01
Apr 6, 2002 10:40 PM
Rieger328Ci
Mar 24, 2002 03:33 PM
