quote i read in a magazine, is this true can any one explain further?
Old 03-31-2015, 08:11 PM
beefystud's Avatar
Default quote i read in a magazine, is this true can any one explain further?
heres a quote i read in a magazine, is this true? can any one explain further?
"ever wonder why the brakes dont work well on your recently turbochardged car ? when adding a supercharger or turbocharger to a naturally aspirated vehicle, a lack of vacuum can severely reduce brake pressure"
Old 04-01-2015, 06:32 AM
King Tut's Avatar
While a lack of vacuum can reduce brake pressure due to the vacuum brake booster, I don't see why adding a turbocharger or a supercharger will reduce vacuum unless you create a vacuum leak.
Old 04-01-2015, 06:37 AM
illestrolla's Avatar
Was this an April fools edition?
This is bad information if you ask me. This is implying the booster is depleted AND you're on the gas + brakes at the same time? Who the hell does that?!?!?!? The second you're off throttle you're back in vacuum and have brake assist.
Old 04-01-2015, 10:32 AM
beefystud's Avatar
its was an advert in the latest issue of DSPORT for this http://www.forgemotorsport.co.uk/One...uct--1304.html
Old 04-01-2015, 12:46 PM
King Tut's Avatar
Our brake booster line has a check valve in it already.
Old 04-01-2015, 01:05 PM
RacerXI's Avatar
If the check valve was removed, lack of pressure could be an issue.
Old 04-01-2015, 03:15 PM
hybrdthry911's Avatar
Excluding brake boosting....Who uses the brakes while they are WOT?
Old 04-01-2015, 03:22 PM
99SH's Avatar
Serious question - why would a NA car have a check-valve to the brake booster?
I know we do, but do all NA cars?
Old 04-01-2015, 03:37 PM
My guess would be to maintain the vacuum even when WOT, if there was no check valve it would lose the vacuum at WOT.
Old 04-01-2015, 04:24 PM
cleenyc99's Avatar
most n/a cars don't have a check valve. shocked to lean we do. maybe we do because our VE is high and revs to 8k so there could be a chance the s2k makes very little vacuum at WOT on an n/a car. with a turbo car. when making boost the engine has no vacuum (it has psi) to assist with the brakes. so the check valve allows the booster to retain vacuum while boosting. so when you let off and push the brakes the car stops. if you remove this valve you will have a very hard pedal when driving. car wont want 2 stop. I've added turbo's to other cars and had this problem
RACER
07-07-2023 10:05 AM
CKit
11-14-2009 09:31 AM
stealthx32
05-24-2008 03:03 PM
SPLNDID
08-18-2006 08:18 AM
Pinky
06-11-2001 10:01 AM
Quick Reply: quote i read in a magazine, is this true can any one explain further?
