Recommended way to change oil w/Comptech SC
It's about time to change the oil for the first time with the Comptech SC....there's two fittings in the oil pan instead of just a drain bolt. Which one should I unscrew? They're also aluminum--what's the recommended torque for the fasteners?
You mean unscrew the 90 Deg. connector from the male/male connector that screws into the pan? (It's not reverse threaded, is it?)
Obviously sockets can't be used and space is very tight down there with the Digrappa XBrace. Any tricks for making it easier?
I did mine the weekend before last. Just unscrewed the 90 degree connector and let it drain out. Once it had finished I screwed it bad on firmly but not too tight.
With regard to the X brace: Get a Muz/WhiteLine. No problem at all.
(not to tight, just right amount of pressure
easier for me
