RED is alive!
Old Oct 18, 2007 | 07:53 PM
CourageOO7's Avatar
ewww! Yuck! I would have freaked!
Old Oct 20, 2007 | 12:06 PM
c_me_go's Avatar
Dammmm!!!! that must of sounds like finger nails on a chalk board...
Old Nov 5, 2007 | 09:09 AM
nibble's Avatar
update on this. I also posted this in under the hood forum but please help me if you have any suggestion.
[QUOTE]
backgorund on what happened,
https://www.s2ki.com/forums/index.php?showtopic=535446
in short, SC was replaced due to catasrophic failure and I put everything back together.
Old Nov 5, 2007 | 09:21 AM
Soul Coughing's Avatar
why dont you just undo the fitting on the supercharger and have a friend start the car for a second... if oil comes out, then you know the supercharger is getting oil!
Old Nov 5, 2007 | 09:58 AM
nibble's Avatar
disassemble it for the 4th time? every time I do that, I promise myself this will be the last time.
I'm hoping that I could check without disassembling it or things I can check before I take it to shop for inspection on oil pump.
thanks.
Old Nov 5, 2007 | 12:23 PM
can't you just unscrew the oil line? i know on the comptech setup the line was on teh top, not sure about the vortech setup
Old Nov 5, 2007 | 07:30 PM
nibble's Avatar
the oil line for vortech is in between SC and mounting plate. then it routes to bottom side in between where no figer can reach.
only way to unscrew it from the SC is dismounting SC. from engine side, there are room just enough for my fingers to get in and touch the screw on the line...
so it's a quite a challenge.
Old Nov 5, 2007 | 07:43 PM
Venomous S's Avatar
You should be able to disconnect the feed line where it connects at the brass fitting that vortech SC ships with.
Old Nov 5, 2007 | 09:09 PM
Aze85's Avatar
wow, that thing was messed up!!!
glad to hear that u didnt damage your engine
SickoS2K
Apr 9, 2018 08:19 AM
Sherman818
May 18, 2012 07:11 PM
Jay-Z
Oct 15, 2008 10:48 PM
YellowS2kPwr
Jul 16, 2005 02:57 PM
fltsfshr
Jul 8, 2004 11:37 AM
