s/c cooling question
Old Jul 19, 2010 | 10:41 AM
  #21
s2000Junky's Avatar
Originally Posted by Thunder-rush,Jul 19 2010, 10:18 AM
It's a toss-up between both. Intercoolers are almost maintenance free while watercoolers need more attention. Watercooler in sc give more psi per pulley and better trottle response for lower psi's they are better. Front intercoolers should be more consistent in power than water intercoolers as the waterIC usually sits in the engine compartment gets heat soaked quickly. How many turbo kits run water intercoolers? Put a precision or spearco up front and you can run more timing than watercoolers that get heatsoaked. With front IC you loose .5-2psi of boost depending on pulley but allows you to run more timing in higher boost settings offsetting the pressure drop. For running 5psi of boost might as well put a elbow tube as there's not much heat there.
Not exactly true, typical boost loss is 3-4psi. And you can’t make that power up in cooling efficiency with the fmic, this is just not debatable. Fmic works more efficiently for turbo applications period.
In my humble opinion the most efficient, reliable SC set up is utilizing an A/C, upgraded heat exchanger if you like and water/meth injection. You will make more power per psi safely this way if you’re talking about maximizing your power potential. If your not wanting to maximize your power potential and run less then 10psi on the track, then I can see where an fmic may fit the bill if you would not be running water/meth injection.
ushyaar
May 23, 2009 08:32 AM
s2000Junky
Sep 10, 2008 12:25 PM
RunUrAss
Jul 18, 2008 09:08 AM
jiggarex
Jun 2, 2007 04:50 PM
GoFaassttt
Mar 22, 2006 10:41 AM
