s2knoob's Turbo Build
Old May 19, 2012 | 10:18 AM
  #71
s2knoob89's Avatar
Originally Posted by Navy_crx
Dyno yet???
Nope. I did run a bike up to about 160mph though. Put at least a couple car lengths on him. I don't know what kind of bike it was but it had the rear tire stretched out a bit more than factory and had an exhaust on it
Will try to go to the dyno this week......
Old May 19, 2012 | 12:04 PM
  #72
Navy_crx's Avatar
Thats what i like to hear im getting anxious to get mine running. Look for my build thread later this evening im finaly going to make one ;-)
thread done s2knoob let me know what u think
https://www.s2ki.com/s2000/topic/953...s-turbo-build/
Old May 29, 2012 | 03:46 PM
  #73
sebringap2's Avatar
might be going this same set up quick ? are u running ac ? if so could u show how u routed the lines ...... buying this manifold this weekend
Old May 30, 2012 | 05:32 AM
  #74
Redline S2K's Avatar
Most likely running the ac kit sold by a member on here, ghettocrx
Sent from my SPH-D710 using Tapatalk 2
Old May 30, 2012 | 07:26 AM
  #75
spectacle's Avatar
Your build looks great and is eerily similar to mine. I have a few questions:
Originally Posted by s2knoob89
I managed to get the stock pressure sensor threaded back in and snugged down. So now I go to plan B for the oil feed. I used a banjo fitting on the vtec pressure sensor port.
It's been a while since you've had the turbo going now...how is your turbo doing on shaft play? The reason I ask is I was under the impression that the vtec pressure port doesn't see consistent oil pressure unless the motor is in VTEC, which would not be a good thing for the turbo, especially a journal bearing one that isn't using water cooling. Is yours holding up so far?
ID1000's (Flipped the harness underneath the manifold for a cleaner look)
How exactly did you do this? Did you have to extend any wires?
I'm seeing full boost at 4400rpm which is nice!
How much is "full boost" and in what gear? Can you post a datalog?
And of course...has it seen the dyno yet?
Again, great build. Thanks for sharing.
Old May 30, 2012 | 09:53 AM
  #76
s2knoob89's Avatar
Side to side shaft play has increased slightly from when it was new but nothing crazy and still has zero in & out shaft play.
The plug n play clips that are supplied with the injectors give enough slack to route the harness underneath the manifold.
Full boost at 4400 rpm is acheived when I go full throttle from around 2000 rpm in 4th gear. Now if I'm cruising on the highway boost builds almost instantly.
I'm going to call the shop today and see about getting it on the dyno.
Old May 30, 2012 | 10:14 AM
  #77
s2knoob89's Avatar
Got an appointment tomorrow morning for the dyno.
Old May 30, 2012 | 10:18 AM
  #78
spectacle's Avatar
Full boost at 4400 rpm is acheived when I go full throttle from around 2000 rpm. Now if I'm cruising on the highway boost builds almost instantly.
Thanks but you didn't answer my question.
Old May 30, 2012 | 10:34 AM
  #79
s2knoob89's Avatar
Fixed. If you need a data log I can post it.
Old May 30, 2012 | 10:57 AM
  #80
spectacle's Avatar
I would greatly appreciate a log. How much boost is "full boost" for you?
