SC potential issues for tranny and diff.?
Old Jan 19, 2012 | 09:32 PM
cpaforever's Avatar
Default SC potential issues for tranny and diff.?
Hi guys,
I'm thinking about a supercharger, my concerns is could the extra power cause problems on the transmission and differential? are they strong enough to handle the extra HP without having problems? Has anyone seen/experienced these types of problems due to a SC or turbo?
(I don't plan to make it too powerful, but somewhere around 300WHP is good enough for me. )
Thanks in advance
Old Jan 19, 2012 | 10:33 PM
s2k manic's Avatar
diff and clutch check diff fluid make sure it doesnt look burnt or black/slivery . jack up rear end put it in gear e brake off rotate left rear forward right rear should turn other way that will tell you torenson is in good shape. if clutch is strong it can last maybe 5k or more no hard launches bang shifting ap2 delay valve helps really liking comptech so far . by the way if when you turn rear wheel and the other dosent trun or is interment the center section is worn out .look up the lsd design there ware items need good fuild ever 6k if you drive hard hope this helps..
Old Jan 20, 2012 | 11:16 AM
Moddiction's Avatar
Former Sponsor
Shouldn't have an issue as long as you dont launch incorrectly or anything. I have been over 300whp for 2 years and over 400whp for 1 year now. No issues at all and I get on it as much as I can. No launched or tracking it yet though.
Old Jan 20, 2012 | 11:20 AM
passmans2kny's Avatar
just take it easy in 1-2 gear and the drive train should hold 500hp for a long time, u can break this stuff at stock power if u launch from a stand still
Old Jan 20, 2012 | 12:35 PM
Diego@Ptuning.com's Avatar
Everything should hold. Its all how about you drive the car. I got customers with our p-tuning turbo kit putting out 500+ with stock differential. So far from what I have seen no destruction yet. Like passman said tho take it easy in 1-2 and dont launch the car and you should be fine. Its all about how you transfer the shock loads to the diff. If it does go out, go for a puddy mod built diff!
Old Jan 20, 2012 | 12:42 PM
another thing I forgot to mention is upgrading the clutch. Something you might wana look into.
Old Jan 20, 2012 | 12:45 PM
ftpsk8's Avatar
Trans and diff are the weak points on this car. Anytime you introduce boost it will put more wear on these parts. But, like everyone else says, just don't launch your car and take it easy in 1st and 2nd. Do that and you should be fine up to 500whp I would say.
Old Jan 20, 2012 | 03:41 PM
steven975's Avatar
I've been almost a year at just over 300whp...stock tranny, stock diff...and stock clutch...and no problems other than pitting an inner CV joint cup, which happens to many if not most S2Ks.
I don't think anyone in the 300whp class has blown any drivetrain component that wasn't abusing it.
Used diffs and trannies are super-cheap, anyway, especially AP1 components.
Old Jan 20, 2012 | 09:07 PM
cpaforever's Avatar
cool thanks guys.
Josh226
Aug 18, 2013 02:52 PM
eMokhtarian
Oct 12, 2008 01:07 PM
Rev Happy
Feb 15, 2008 10:04 AM
BowerS2K
Feb 16, 2006 04:38 AM
Babyjoy
Jun 3, 2002 06:40 PM
