School me on head upgrades
I went with All Supertech Stuff, the Inconel Exhuast valves saved my ass, I am pretty sure if it was stock when I had my manifold glowing for a solid two minutes I would have warped em, those lil bastards held strong
Also, I know you know your shit, and I am by no means trying to educate you, but you pushed the motor on METH and it popped the motor, why would you want to run this motor up to 9,000RPMS with 600+ hp?
From what I can see from the gear calculator, the biggest difference is the "reduction gear" in the Ap1 trans, seems the actual gear ratios between the 2 are the same, sans 4th/5th gear, but for the most part identical.
W/that said, the added redline helped gain a good bit of mph.
I'm going to get it some sort of valvetrain, b/c 2step/anti-lag on the track is hell on a head to behind with.
As for reving it out, why not? It's power there? It's not going to be a daily thing, my Si (which was a 1.6) reved out to 9k, cousin reved it out to 9500, which was a semi-built block/head. Now it's hitting 10k+ on a fully built setup. Yes I understand the rod/stroke ration was far less than a 2.2 is, but I still think it's reasonable.
I don't see any reason it can't handle it w/the right parts. For track use. Besides a little added insurance against over-rev/etc is always nice.
stock valves will usually make more power.. IMHO unless they are messed up there isnt really a need to replace them. If you do replace the valves dont go cheap.. get the GOOD ferrea's. There are cheap ones and good ones.
I have been turning my motor 9300 rpms for 11k miles now.. It sees 9000+ probably 10 times a day ... at least.
I wouldnt rev stock f22 rods to 9500 rpms, but if you have aftermarket forged rods its not going to be a problem.
Regardless, I'm getting some valvesprings/retainers.
I'm on Carillo's, I think they will take the spinning.
its not about the flow w/ferrea vs supertech.. every time the question has come up with anyone i have ever used for head work they say the good ferrea's are worth the price when it comes to reliability. These motors have "small" valve stems so a good valve is very necessary.
good choice on the carillo's
Adam,
I keep forgetting the smart guys don't daily their cars like me
. In that case, REV away
I got all my stuff for a great price from lasky, they have good packages
Also here is an older thread of mine where a few people chimed in on Valves, some nice pics too
https://www.s2ki.com/forums/index.ph...ic=728967&st=0
They swapped valves, and still ran 8 sec passes. To me thats worth it's weight in gold.
I asked them why not supertech, and they said they have seen them break, well I'm a believer.
