ScienceofSpeed Supercharger System Updates
Originally Posted by integuy98,Oct 29 2009, 10:49 PM
Just out of curiousity, would a dyno run with the SC belt off provide numbers that mimic the car pre-supercharger?
that would make the engine run massively rich!! and maybe break it????
Originally Posted by camuman,Oct 30 2009, 06:41 AM
if the belt is off, you wont hit boost, and you wont add the fuel/pull timing that is associated with boost. so no, you would not run rich and destroy the car. if anything, u may run a bit slower then na, since the air is being pulled thru a shitty NA intake now ROFL.
Belts break, would suck if the motor went south becuase of a SC belt breaking. Wont happen. No belt, no boost, no problem.
Through my substantial awesomeness, I managed to break the belt on mine in the first week. I ended up running around with everything installed and no belt for about a month. Of course since I was essentially NA with a crappy intake, I used my old NA ecu map and tweaked it to run nicely. It was actually a real nice tune all things considering, but definitely slower than a stock S2000. So, no, running without a belt is not a major concern. Its a lot more fun with one though.
J
J
^ oh ok. hmmm i was told that it would run rich cause of the hondata reflash. i mean the engine is expecting all this air but no air cause belt is off.
anyways i actually ran my car without the belt becauase the s/c pulley bolt fell off and destroyed my belt. i didnt rev it pas 3k cause i thought id break my car. lol now i know i can a least drive it home if it every breaks down or something
Here's my dyno sheet of my SOS SC w/ AC.
2004 AP2, ~80000 miles, all stock except for SC.
Dyno: Dynapack 3000
Temp: ~70-75 F
Max HP: ~293 @8200 RPM
Max TQ: ~188 "
Max boost: 6.5 lbs "
I keep hearing people say Dynapacks should run high because it's measured at the hubs. If that's the case then my numbers look kinda low.
What do ya'll think?
Unfortunately I don't have a pre-install baseline dyno. This was done at Blacktrax Performance in Northern California. Looking at some of the previous dynos of stock AP2s from Blacktrax, I think the HP numbers ranged from 20x - 21x. If that's the case, My increase could have been anywhere from ~73 to 93 WHP...
Dyno: Dynapack 3000
Temp: ~70-75 F
Max TQ: ~188 "
