SOS install pics
Using a Walbro 255 external pump & an external fuel surge tank. I had this installed last year, so no pics.
I'm not sure how realistic it is, but my goal is 380 whp. Running a 10psi pulley on a 1200 blower.
That's just pipe sealant spewing out. The fitting (Earl's) is fully threaded in to the blower. The only difficultly I had is installing the braided line to the drain plug. You need to hold the AN/NPT adapter with a wrench which to keep it from turning. With the limited space, this is somewhat difficult.
Awesome numbers. What psi is that at? Since you're using the Tial Q, how did you cover up the hole on the intake pipe where the Bosch BOV was?
Shouldn't there be a hole in the intake pipe since you're not using the SOS Bosch BOV?
