SOS install pics
I love the little circuit board dash you got going with the switches. I always wondered: are air tubes feeding all the way to the bottom like that too long to be functional??? I figured from common sense physics, its not always a good thing. perhaps the air filter should go right by the opening where the rad fan is and then make the duct come close to that filter so it gets outside air and the surrounding, closer, quicker air at the same time. its a stupid idea maybe, but im just thinking about the velocity of air during a very long flow like that. any physics majors here?
either way, its not that much of a matter- everything else is coming along very nicely here!
I made two minor changes. I added a LED indicated for each of the fan switches. There was one instance where the crimp to the +12V power had vibrated loose and didnt know about it. This illumination will help me confirm that power is going to the fans.
Also, to increase the clearance between the aftercooler and strut bar I purchased a master cylinder brace. Gives me clearance & a better braking feel
...and the obligatory Tial BOV sounds. Here's a short 40 second clip
[media]http://www.youtube.com/watch?v=DQXagwx6X8s&feature=youtu.be[/media]
the video is good, exactly what I expected. 3 years ago, I had a CTSC with a Ultimate racing FMIC with a TiAL BOV, it fluttered a lot on partial driving. Have you noticed this at all? What spring are you using? I recall the springs being measured by vacuum, not PSI. Any thoughts on this?
I'm using a 10psi spring (grey). It does not flutter whatsoever. It's either on or off. The car is pulling 20-25 inHg of vacuum, which equates to 9.82 - 12.28 psi. I'm also running a healthy 3/8" vacuum line directly behind the TB (I believe this goes to the EVAP) all the way to the BOV. At the BOV I have a 3/8->1/4 reducer and connect it to their supplied banjo air fitting. The overall length of the hose is pretty short, maybe 12-14" long, which helps the BOV performance as well.
The plastic filler is called Urethane Supply 2020-T SMC Hardset (http://www.handsontools.com/Urethane...t_p_57747.html)
Love that BOV! Fun to hear it; fun to watch it moving. Great vid!
